I will take my chance. If you know what lighting system to use you get perfect light. I just want to know if the 5 has PWM or not. Thanks.
What science have you seen that refutes the Laws of Physics as they are currently known?daniel stern is a joke. I have used HID in my previous 5 and they were perfect. No stray light, No flashing by others, no blinding light when in crappy weather. I run LED in my 2016 F150 and it's the same, perfect cutoff, no stray light no flashing by others.
Dropping HID/LED into halogen reflector headlights is the big no-no but Mazda uses a projector lens that is the x-factor (Daniel Stern argue this too but I disagree based on many empirical user experiences I've come across). Stick with a better set of HIDs b/c the bulb projects light, unlike LEDs which scatter (need proper housing to focus/refract light where its needed) and doesn't give you the 'down the road' lighting you need at HWY speed. From a simple visual, I'm pretty sure the GT's HID uses the same projector housing as the non-GT. I recall old posts of folks trying LEDs and while it looks (stupid) bright in front of you it doesn't go far enough down the road and there's a lot more scatter (blinding) above the projector's cut-off. Then again, aftermarket LED bulbs likely have evolved so hard to say how they perform today and, like all things, YGWYPF. There's also the counter argument that most roads are very well lit; lots of people drive not knowing their headlights are off...daniel stern is a joke. I have used HID in my previous 5 and they were perfect. No stray light, No flashing by others, no blinding light when in crappy weather. I run LED in my 2016 F150 and it's the same, perfect cutoff, no stray light no flashing by others.
I had HID in my 2007 and they were AWESOME. Pushing light down the road. everything I have read that daniel the "expert" say is crap is just the opposite. He has an agenda and that is to profit from his "knowledge". I agree with the LED in the housings for the 5 and HID works MUCH better. I am not an LED lighting fan by any stretch. I like HID, but I was wondering until I can get some HID from retrofitsource.Dropping HID/LED into halogen reflector headlights is the big no-no but Mazda uses a projector lens that is the x-factor (Daniel Stern argue this too but I disagree based on many empirical user experiences I've come across). Stick with a better set of HIDs b/c the bulb projects light, unlike LEDs which scatter (need proper housing to focus/refract light where its needed) and doesn't give you the 'down the road' lighting you need at HWY speed. From a simple visual, I'm pretty sure the GT's HID uses the same projector housing as the non-GT. I recall old posts of folks trying LEDs and while it looks (stupid) bright in front of you it doesn't go far enough down the road and there's a lot more scatter (blinding) above the projector's cut-off. Then again, aftermarket LED bulbs likely have evolved so hard to say how they perform today and, like all things, YGWYPF. There's also the counter argument that most roads are very well lit; lots of people drive not knowing their headlights are off...
Here is my static review (beam pattern, Lux measurement) of various headlight bulb options for the Mazda5, or any vehicle that uses the H11 bulb.
My dynamic review (driving) can be found HERE.
I will be reviewing DDM HID kit soon.
Here is the test setup that I used for this quick evaluation. Test surface is a bedsheet (I'm going to call it a screen) stretched over lumber, with a second thicker sheet behind, to reduce light bleeding through and confounding measurements. Distance from headlamp to screen is 2.1m (about 7ft, the max I can achieve in my garage, and I want to stay in the...
- sac02
- Forum: Mazda5 Forum
Consider salvage yards for OEM HIDs (OE Sylvania D1S bulbs are super bright!) and you can pull the toggle switch to get manual light leveling? Someone here posted a conversion guide and it is not difficult.
Oh, and @Silentnoise713, LED technology has come A LONG WAY in 11 years. The LED kits back when the post you linked was new, were sewage. If you noticed I was commenting way back then because I still had my first 5.Dropping HID/LED into halogen reflector headlights is the big no-no but Mazda uses a projector lens that is the x-factor (Daniel Stern argue this too but I disagree based on many empirical user experiences I've come across). Stick with a better set of HIDs b/c the bulb projects light, unlike LEDs which scatter (need proper housing to focus/refract light where its needed) and doesn't give you the 'down the road' lighting you need at HWY speed. From a simple visual, I'm pretty sure the GT's HID uses the same projector housing as the non-GT. I recall old posts of folks trying LEDs and while it looks (stupid) bright in front of you it doesn't go far enough down the road and there's a lot more scatter (blinding) above the projector's cut-off. Then again, aftermarket LED bulbs likely have evolved so hard to say how they perform today and, like all things, YGWYPF. There's also the counter argument that most roads are very well lit; lots of people drive not knowing their headlights are off...
- sac02
Except if you're behind me in my Miata. Then your F150 may as well be Satan himself.As for LED in reflector housing being a no no? I have 2016 F150 that disputes that claim directly. Proper cutoff, and great beam pattern. No getting flashed by on coming drivers. Had my wife drive past me going the other way and she said they were fine like any other HID/LED factory housing.
I know nothing on this topic, just came to see how this pic fits in any discussion.Except if you're behind me in my Miata. Then your F150 may as well be Satan himself.
That has nothing to do with the lights and all to do with the miata.Except if you're behind me in my Miata. Then your F150 may as well be Satan himself.
They are........ok. Beam pattern is great but they don't have what I am looking for. They are brighter than the halogens, but not nearly as good as my F150 lights. I am returning them and going with another brand. Report on those soon.Let's see how this set does. They are ignite brand from Canadian Tire. I am waiting for the dark to give them a proper try. Against my white garage door the beam pattern is exactly the same as the halogen, maybe a little wider because halogen sucks prairie oysters anyways. But ANYTHING is better than the halogen bulbs.
Hilarious, but the problem with F150's (and many trucks on the road today) is that they don't properly aim their headlights down at the road. They just seem to beam to infinity. Mazda is so much better at this. We don't have the BT.50 here but if we did I'm sure it's engineered similarly to their cars with properly aimed and cutoff headlights.That has nothing to do with the lights and all to do with the miata.
