What have you done to your Mazda5 today?
Replaced the front and back hood seals to try and keep the torrential rain we've had from getting into that #1 spark plug well. Still on the list, fix the horns, wire up DRL's, Rear main seal, Oil separator/PCV valve, ... the list goes on.
Custom rate BC coils.
Been in Japan for a month and finally got back home and got to drive the Mazda.
Really missed driving this car. Just nice and comfy to drive in.
Just installed my LED lights in the low beam. Waiting for the night to see if I have to get a better set. The ones I bought were the ignite brand from Canadian tire. Had a good week of bonuses at work so i took some and bought the bulbs. Night pics in a few hours.
Those lights I bought were not good. The reviews were mixed some said super bright some said NOPE. I say NOPE. they were a little brighter than the old original halogens in the car, but no where near what I was looking for.
Next up is to order a set off amazon and give them a go. The cut off and pattern were great, just no punch to them. If the next set does not do it, I will be getting 4300k 35w HID and be done, I know they work in the headlights right.
Put new ice radials on for the winter. First winter in a long time for us with a 5. It's very different coming from the Jeep patriot where we can just blow through the snow and drifts. ha ha.
We will have the F150 though.
Ah yeah, tis the season for studs! I've always been impressed with how well the 5 does on packed snow and ice.
Yes, we were impressed with our previous 5 as well. We had Toyo Ice radials on that one and they were the best snow tires we have ever owned on any vehicle. This time however we could not wait to get them in so we bought cheaper tires and will order Toyos next year.
Have a look at bayson R, I ordered their complete kit without spoiler for our 2007 5, and we are ordering the entire kit with spoiler for our 2017 5. They have great products.
Had an interesting issue with the Mazda5 the other day - intermittently while driving, I couldn't push the shifter over into 1st or 2nd at a stoplight or two, then at the next one it worked fine. Occasionally I couldn't get into reverse as well until the car had moved, but only about 1 in 4 or 5 times. Double-clutching didn't make a difference, pushing down the shifter (like going into reverse) didn't help when trying to get into 1st or 2nd, but on some occasions the shifter could be forced over enough to slide up into gear (others not). This happened for about a week before I could take a look at it - thinking it was a problem with the reverse lock-out I started at the shifter inside the car, but in the end the problem was...
A squirrel left a walnut on top of the transmission, which occasionally would roll in the way of one of the shifter arms and get wedged between it and part of the casing, preventing the shifter arm from moving over far enough. Sometimes it would get wedged just right, sometimes not, maybe dependent on previous braking, pointing uphill or down etc? Either way, that was an odd and frustrating one that turned out to be a pretty simple fix once the battery box and airbox were out of the way.
I had a 2001 subaru Legacy GT that I had a twin turbo system installed on. Went out one morning and it would not fire. I am like oh great, something major is done now. Turns out, a rat ate my spark plug wires. I installed a set of nice blue NGK 9.5mm wires and away we went again.
This was the first time that rodents caused damage to the Mazda5, but in the past they got into the HVAC inlet in the RX-8, chewed through the cabin air filter and the blend door, and made a nest in the blower cage (which burned out the resistor when I tried to turn it on the next time). That one required a lot of cleaning out and re-gluing HVAC pieces, and there is still a faint whiff of hay in the car. They also left walnuts in the wiper cavity of that car which would cause the wipers to jam from time to time.
They also got into my wife's Subaru Legacy through the rear HVAC outlet behind the bumper cover, and chewed through the baffles there plus brake light wiring and made quite the mess.
I went with VLEDS for my low beams and used them for years! Great light but a little on the pricey side. I just recently swapped to a pair of Boslla 'switchback' head lamps due to California being extremely foggy this winter season. I have no name LEDs for my high beams and the light isnt great.
I have sealight S1 Pros in both the low beam and high beam now and they are fantastic. MUCH better light.
