2014~2018 Where to buy a spare tire?
2015 Mazda3
The spare tire that came with the car is about 10 years old now. Its wheel is rusted. I've read that most tires have to be replaced every 6 years or so even if not in use? This spare tire had only been used a few times when I've had a flat. Is this a dealership only item?
look on ebay
the tire sitting inside the car should never be exposed to sunlight, so in theory it should last "forever"... UV is what damages the rubber and is why tires gets dry rotted and need to be replaced
the only time you need to replace a spare tire is when it's visbly damaged... happened to our corolla's... the tread started separating from the rest of the tire... apparently common on those cars but never seen it happen before
I found a single rim with brand new tire off a 2007 Lexus ES350 with similar wheel specs as the original wheel and tire on my Mazda 6 as a spare. It's heavy, but far better than using one of those crappy donuts.
