No rear speakers. Aftermarket speaker recommendations?
Our new 2025 cx30 preferredis a great car, however, we were very surprised that Mazda discontinued the rear speaker from previous models without disclosing this. . There are rear speaker grills but they are empty! There is a virtual control for moving sound to the rear , but again no speakers , so that is useless!
The speaker front/ rear fader control is also useless as there are no rear speakers. These all seems a bit misleading. I also see that that there is a recent class action suit against Mazda for a similar issue with the Mazda3 speakers.
Crutchfield sells speakers to fit the rear and I see some wires but the Mazda dealer tells me it is not possible to upgrade which seems very odd.
Has anyone had success in upgrading their 2025 cx30 preferred (6 speaker system), to put speakers behind those empty rear grills? And if so, was the installation plug and play, using the existing wiring and virtual sound system controls (such as fader and speaker selection options on the console)?
Thank You, Mike
Before you go spending a bunch of money, you first need to figure out if those wires actually have a signal on them. Get any old random speaker and use some alligator clips to temporarily attach it to the speaker wires. If you hear sound, you're good to go. If not, check the settings on the radio, make sure you're not faded all the way to the front. If you're not faded all the way to the front, and you still don't hear any sound, then there's simply no sound. It is what it is. No soup for you.
You could always take the effort to add an amp and run new speaker wires, and all that entails, but we're talking about rear speakers here. Nobody who cares about how a stereo sounds cares. Think about it this way: when you go to a pub or venue to see a live band, do you face the band or sit with your back to them? Obviously you face them. That right there is why rear speakers are almost meaningless. Music comes from in front of you.
Now all that said, Mazda base stereos are pretty awful. The upgraded Bose stereos are barely tolerable. I'm a big time music junkie. I don't mind putting in *a lot* of time, effort, and money chasing great sound. And I've had an upgraded stereo in every single car I've ever owned, including my 21 CX-9 where I changed out everything except for the head unit, and that's only because you can't change it out.
A word of advice, any money you would have set aside for rear speakers, put that towards better front speakers instead. And the craptacular front speakers you have now, (assuming you have singal back there), move those to the back.
Thank You, Mike
I must be going deaf. I seem to hear rear speakers in my 25 preferred plus there’s not a powered pass. seat, folding mirrors, but does have an annoying rattle in pass side dash.
Yep, just checked to be sure. You do have to adjust the rear speaker to max to get sound. I adjusted it to put out a little sound and it seemed to increase bass a lot
Looking to replace the front door tweeters in pillar and center. I think the existing Bose are 2ohm. 2025 CX5 SPORT TURBO.
Has anyone done this and will loose gain with the factory amp settings?
Corporate Mazda confirmed that there are no rear speakers behind the rear door grills. I took the grills apart and there are no rear speakers on the cx30 preferred. There are speakers that project to the rear but the rear door speaker grills have nothing behind them, Mazda decided to save a buck and go from 8 speakers to 6, unless you have the Bose system.
I couldn't believe it, i had to check the wiring diagram to confirm it and it's true!
Did you find any wiring behind the grills? The amp could be active but Mazda doesn't add equipment if it's not needed.
Yes wiring connectors are behind the grill. I was not able to get any sound out of a temporary speaker I attempted to hook up to it. Mazda dealers were no help, Corporate Mazda Customer service were of no help when I asked if it may be a software issue as the display has a rear fader which does nothing.
People will sue over anything, I swear.
As I said before, rear speakers are almost worthless anyway, and in our 21 CX-9, even at full blast, you can hardly hear them anyway.
"can hardly hear them" from where? as the driver? I'm pretty sure if you sat in the backseat, you can hear the difference... why put in 4 doors and backseats then?
Hell, you can hardly hear them sitting in the back seat.
I truly believe Mazda did this intentionally, to try to build a half decent soundstage. Go listen to any *truly* good car stereo, one that competes in the Sound Quality League in MECA or IASCA. Those cars will absolutely blow you away. And hardly any of them use rear speakers.
Not a complaint, as such ... Just my 2¢ worth, here.
I'm not sure that adding speakers would be worth the expense to me. Firstly, the EQ settings offered in the trim of vehicle that I own are minimal (Treble and Bass...no Midrange) and even if there were there is really no way to adjust EQ "on the fly" to compensate for genres of music which are recorded with emphasis on different frequencies. As a result, I find myself listening to talk radio more than music these days.
Doubled check my 2025. Got my wife and neighbor to confirm there is sound from rear door speakers. Maybe mines special🤨
