Loud creaking deep in dash
elpres666
2018 CX-5 Sport Nav Plus AWD
Hi all
My first forum post so please be gentle :)
I've got a 2018 CX-5 Sport Nav Plus AWD and I love the car except for the squeaks and rattles - I previously had a 2013 and I feel like the build quality of the trim has decreased. There were a lot of squeaks of dash trim rubbing against itself which I've resolved with felt tape but I have a problem that's big enough to make me consider getting rid of the car. It sounds like hard plastic on hard plastic and can vary from a light tap to a squeak like a creaking bed spring!
When the ambient temp is mild (around 18C-25C) and sun is shining on the dash, I get a terrible creak/tap sound from deep inside the dash behind the instrument binnacle on the driver's side (this is the UK so RHD). It's not dash trim panels, nor is it A/C, vents or heater fan. It's something deeper inside. I've tried to record it on my phone, but phones are designed to filter background noise so it sounds much more minor than it actually is.
The dealer is trying to help, but of course every time I bring it in they can't reproduce it. And then we take it home and it's happening all the time. it's so loud that passengers in the back seat will remark on it even with the radio on!
I've seen some recordings of similar sounds online which are suggested to have been either insufficient windscreen bonding or insufficient sealant on the Active Driving Display. I could get the windscreen re-fitted, but since I have a couple of chips there's a risk it'll crack and I'll have to pay for a new screen. And the Mazda fix for the Active Driving Display is to replace the thing, and that means removing the whole dash, total cost GBP 1600! Yikes.
What I'd really like to do is to be able to diagnose what the problem is. Honestly, it's so bad.
Also, although this is minor, a couple of months ago I started getting a high-pitched whistling sound on the driver's side which occurs between 50 and 60mph. This sounds much more trim-related and I've heard similar on a car which had a loose roof rail cover. But even this the mechanics can't hear! Can anyone advise what to check? I've looked at the roof rail panels and the trim around the base of the windscreen, which is loose and moveable but apparently it should be.
Thanks
... When the ambient temp is mild (around 18C-25C) and sun is shining on the dash, I get a terrible creak/tap sound from deep inside the dash behind the instrument binnacle on the driver's side (this is the UK so RHD). ...
Has anyone checked the tightness of cowl bolts (under the hood). I would think taking it to a dealership they would, but you 🤷‍♂️ never know.
I very much doubt it knowing them...if you mean on the plastic cowling, the bolts are tight but the cowling moves and when I asked them about this they said it's meant to (?!)
Agree with the above. I'm getting it even on my new (well, it still feels new and has only 7000 miles) car when I exit the driveway at an angle to the right, which puts uneven stress on the two sides of the car.
This sounds promising, where exactly are you referring to?
Cowling bolts location -- under the hood, immediately ahead of the windshield wipers, between the shock tower upper mounting bolts (at least in my 2016 Mazda CX-5). 17-22 in-lbf torque on those 8 bolts.
Thanks for this!
I thought it mikght be those and I went and checked them yesterday. Those bolts were all at the right tightness. But I then checked a few more bolts and found that there were other loose bolts, including one which bolts the wing panel onto the chassis, which was a good half turn out and looked a bit chewed. So it may be that one of those was the culprit - I can't tell until I drive it for a few weeks.
Similar Threads and Articles
