DIY How to replace CX-9 AWD rear engine mount
Mazda CX-9 Signature
2016~2023 CX-9 Rear engine mount aka torque arm part # TK78-39-040
FWD should be much easier, but AWD requires lowering the subframe held by 8 bolts (4 on each side). You will also need to disconnect the end links from the swaybar held by a 14mm bolt.
To start, remove all the under trays. Remove heat shield (1 10mm and 4 push pins). Remove bushing from the exhaust hanger. Disconnect both end links from the sway bar.
Now you are ready!
Remove the 2 17mm bolts holding the mount and loosen the third 17mm bolt.
Loosen the 8 subframe bolts (4 17mm and 4 19mm) and lower the subframe by 0.5".
Use a jack to slight jack up the bottom of the mount bracket.
You should now have enough room to maneuver the mount out by lifting, twisting, and pulling.
  • 20250420_132921_1.mp4
    46.2 MB
Great write up and pictures!
What symptoms were you experiencing?
Thanks! No symptoms really. It was done more as a preventive maintenance at 115k as you can see the rubber wasn't that bad. It was a relatively cheap part and I was able to save on shipping as I needed to get some other things too.
The placebo effect makes me think I'm able to put the power down a bit better now. :)
