CX-5 NA Oil weight 0w20 or 5w30?
2014.5 CX-5 GS FWD 2.5L
Is it ok to use 5w30 in my 2.5L (non turbo)??
The manual states to use 0w20 for US/Canada. 5w30 is an option if living somewhere else.
My other vehicles use 5w30, and always have a case sitting on the shelf. I'll continue to buy that special jug for the CX5 but it would be convenient if they all used the same weight.
Why would you want an oil made to an old spec when there is an updated one available?
(Canadian labeling)
Mazda still recommends and sells it - i get it for $5.23qt and the difference is not going to be noticeable - but if you like it ! more power to ya - if its less$$ i may go for it -
Thanks
Upvote 1
Mazda corporate or the dealership?
If I were staring down bottles of GF-5 and GF-6, or especially GF-7, I would simply take the newest. They have improved the oil's ability to keep pistons clean with fewer deposits, and have reduced timing chain wear. And of course they have made inroads into LSPI prevention. That's enough for me. There's really zero reason to buy GF-5 oil unless it's on super clearance and I only had the NA motor. But at $5 per quart, just get GF-6.
Upvote 0
Yes, I started using it in my 2016 a year ago. The manual is only a recommendation.
Upvote 0
Like many things, there is a preferred solution, and alternatives.
0w20 is preferred and will give better fuel economy.
5w30 is an option.
Upvote 0
I hope this clarifies a bit your dilemma:
CAFE only applies to United States ( I don't know about Canada). The rest of the world doesn't give a sh*t about US CAFE requirements, for the very same car sold all over the globe, Mazda says you can use 5W-30.
The way I understand CAFE, in a very simplistic way, of course: Mazda did some lab test and they showed the results to the legislators, hey, look, if we use this 0W-20 oil we reduce fuel consumption and we comply with your bulls***. And the legislators approved it so Mazda has to put it in writing, for the consumer, to be legally covered for CAFE. But in reality fuel consumption depends on so many factors, including your driving style! Your car will never get to those lab test numbers! Or very unlikely!
So, yes sir, you can use 5W-30, no sweat! Or take this rule ( no science behind it) : do you get snow on the ground in the winter - use 0W-20. Do you live in the lower half of the US, you see snow once every few years or so - you can go with 5W-30.
This question has been asked so many times on this website and at this point I simply do not understand why. Why is this still an issue for a lot of Mazda drivers. I just don't get it.
Will a dealer put in 5w-30 if the customer requests it?
Upvote 0
The whole "switch to 30 if it starts burning oil" thing seems like a strange idea for me. I would rather start using the 30 before any extra ring wear occurred. Not that a little oil consumption is a huge deal but just my opinion.
In my high mileage stop and go urban congestion 2.5 n/a I use 5-40 and it runs well. Nominal viscosity can differ from the actual viscosity too. One brand/type of '30' oil will be thinner than another '30' oil.
Upvote 0
I certainly agree with you. So many people are particular about staying with OEM recommendation of 0W20, even though it is in the interest of slight mpg/emission gain at the expense of overall engine longevity and even performance, IMO. So unfortunately you gotta push this idea gently onto them, because many of us have this idea engrained that you must follow OEM rec. down to the tee.
I have been using 5W30 in this vehicle for many years. I won't ever go back.
Upvote 0
I'd entertain 5W-30 but do not have a reason to cutover at this time.
I have stuck with 0W-20 Mazda moly since new and basically no noticeable oil consumption as a I near 100k miles.
Same thing with 5W-30 since new in my '07 G35x.. no oil consumption
0W-20 in 1UR-FE in my GX 460.. getting close to 100k miles and no oil consumption there
Upvote 0
I see the Mazda GF5 0w20 oil with moly for sale on Ebay all the time.. if they quit making it, do you think this is just leftover stock until its gone? It seems to be readily available so i wonder if they did in fact, quit making it.
Upvote 0
Because oil has to adhere to current specs. GF-5 is an old spec and does not have the more recent advancements for low-speed preignition prevention, among other things related to engine cleanliness.
Upvote 0
The owner's manual specifically states that using 0w-20 is "required to achieve optimum fuel economy." It's all about federal CAFE standards, NOT engine life. Canada/Europe don't have those standards, so their manual says to use 5w-30.
Upvote 0
Mazda has a newer GF6 version now. It's pretty pricey by the quart
Upvote 0
Yes, you can see right on the front of that bottle: "Maximum Fuel Efficiency." It's actually made by Idemitsu Kosan, a company in Japan.
Upvote 0
