Printed a pad for the dead pedal. I made two versions. One is flat (in picture), the other wraps around the right side a little. I am waiting on the epoxy to cure on the Velcro to try the one that wraps around..
Purchased a CX-5 2025 Carbon first of the year and these are my upgrades:
1.) Rear Cargo Mat from Med Center Mazda Parts
2.) Dealer installed rails and rack
3.) Dealer installed rear gate bumper protection
4.) Door sill plates: Amazon.com
5.) Center console tray: https://www.amazon.com (commissions earned)
6.) Dead pedal cover. Did not use brake or accelerator cover. https://www.amazon.com (commissions earned)
7.) Trailer hitch: https://www.etrailer.com/Trailer-Hitch/Mazda/CX-5/2025/C12170.html?VehicleID=202560504
8.) Navigation SD card: https://www.amazon.com (commissions earned)
I am leaning to these as I have scratched the black plastic already:
The only ones are 245/50/19 and 245/45/20. Don't worry about rubbing.
20x9 245/45/20 here with a 2" drop and there's still clearance.
Intake valve cleaning, with the STP Pro Series Intake Valve Cleaner: click.
Bolts for the big splash shield underneath -- A few bolts missing. Will pick up a bunch of them and replace the rusting ones and the missing ones. Haven't been hearing any flapping of that splash shield, but it looked in good condition.
Next cooler day, time to clean the interior.
Took it to get my all seasons swapped back on. They’re telling me I need new rear brakes (2 and 3mm each, respectively) and my front driver side ball joint is failing again, recommending another control arm replacement. 🤦🏼‍♂️ a little annoyed, but the car is rock solid otherwise.
Taking it to get a second opinion, rear differential fluid, transfer case fluid, and transmission fluid replaced in Minneapolis this upcoming week.
I hope that your shop uses the correct fluids...
