Cracked Cylinder Head (2018 CX-9)
Submitted my claim. Supposed to get a response within 30 calendar days. Got the approval after 33 days. But the approved amount is unknown.
I bought my 2018 CX-9 with 52k miles. Shortly after that I read stories of cylinder cracks and didn't sleep the whole night. Well I'm at 81k now and started smelling coolant last week after driving. I'm been watching it and finally saw it drop from the F line to L line and see drops on the garage. I'm 2.5 hours away from the nearest Mazda dealership. Is it possible to drive the car that far or does the problem get increasingly worse?
Where do live that the nearest Mazda dealer is 2.5 hours? There's about 30 Mazda dealers within 2.5 hours from me (MA).
The drive all depends on whether your engine temp is being affected yet. Fortunately you shouldn't have anything to stress over as Mazda should cover. Just have a game plan before making the trip (dealer loaner secured, or be ready if the car overheats on the way).
I live in Northern Michigan. We had a Mazda dealer in town when they were part of Ford. That dealership is a chain with a Mazda dealership that I plan to go to. I plan to ask them if they still have any Mazda certified technicians but I doubt they do. Planning to drive 2 vehicles down.
What I would do is call the dealer, and Mazda Corporate, to ask for their recommendation on whether you should drive it or not. There is a risk of compounding the problem further if the leak worsens during the drive and the engine overheats.
Can I just watch the gauge? Wouldn't a warning light turn on?
You can, but once the engine starts to overheat, the damage may already be done. As it is right now, if the leak is a slow external one, you can just add coolant. But the area where the crack originated has already been weakened. One bad bump in the road could turn a small leak into a big one, and the repair could go from a cylinder head replacement to a full-on engine replacement.
Again, I'm just speculating, you may have zero issues driving it yourself. But I would still check with the dealer and Mazda Corporate to make sure that they will still cover the repair if the problem does happen to get worse on the drive over.
I made it down and it's getting looked at. Wish me luck. No check engine lights but my "change oil soon" notification came on about 60 miles from the dealership. I've owned the car for 2 years and I've never had that notification ever. It still has 2700 miles since I changed the oil and I have been checking coolant and oil levels the last week and keeping everything topped off.
Update on my CX-9. The cylinder head was replaced. It took 2-3 weeks and I got a CX-70 PHEV as a loaner. They said it would be done in 2 days at first but I didn't believe that would happen and thought it was super optimistic. When I got it back there was some residual coolant in some spots so I cleaned it up the best I could because the smell was making me paranoid. I drove it about 3000 miles since and now I'm noticing an oil leak in the driveway. I haven't done a thorough inspection but from what I can tell it's probably the oil pan. I watched a video about the block replacement procedure and I think they do remove the oil pan. Does anyone know what's involved with dropping the pan and resealing the gasket? I did my Jeep oil pan but just wondering if it's something they can easily do during the next oil change or does it involve removing a bunch of other stuff.
Was yours a Turbo?
Honestly, I wouldn’t recommend tackling this on your own, especially since the issue started after the cylinder head was replaced. I’d suggest taking the vehicle back to the dealership that performed the work and have one of their technicians inspect it. You may still be within the warranty period for the cylinder head replacement, which could cover the oil pan leak. That’s what I would have done before attempting any repairs myself.
However, if you’d rather not go back to the dealership or deal with them again, I can try to find a service manual for removing and installing the oil pan and gasket.
I'm not planning to do it myself. I was just wondering if it's easy to do so they don't have to keep my car for a few days. I don't live near the dealership.
According to Mazda, the suggested repair time is 1.2-2.1 hours. So you can probably either wait in the dealership or get a loaner for the time being.
We had our engine replaced and the dealer mechanic never sealed the flywheel bolts and oil leaked from between the block and the trans. I know you said your head was replaced and not the whole long block. Just thought I'd share if for some reason they did replace the whole thing, just something to check.
Does anyone know if I can have this issue checked for before my CPO runs out at an independent mechanic without taking anything apart?
In other words, can I have someone visually inspect the underbody to see if this issue is present (and other powder train issues as well) before the CPO runs out?
Yes, if the coolant leak is present, there will be a crusty, light green residue on the underside of the vehicle. If it has leaked enough, you'd be able to see the residue on the plastic underbody panels without even removing the panels. You'd also be able to smell the coolant.
If the leak has just started, it will likely drip down from the engine block and onto the engine oil filter.
Removing the plastic access panel for the engine oil filter will show a portion of the transmission fluid pan so you can see if it's leaking. The rear differential is exposed, so you'd be able to inspect it without removing any panels.
If you have ramps or a hydraulic floor jack at home, you can do this inspection yourself. Just be sure to use jackstands where necessary.
