CX-30 Cupholder Light and Evo One Install
rzc
2019 CX5 Signature, Snowflake White Pearl
2023 CX30 Select, Jet Black
The CX30 has a design flaw in that the cup holder area is not adequately lit at night. To rectify this, I conceived a solution.
Everything was soldered, heat shrink, wireloom, etc..
So I did this...
... but in order to get it done, I had to take almost everything literally apart.
I made sure the light is centered...
I then tap'd into the ECU white wire to get the ACC power.
So, since I was in there already.... I went ahead and added the t-harness and installed the Evo One.
Here's the video of me testing the Evo One Remote Start.
Here’s the pic of the light at night…. I can’t complain.
That's it. It was a very productive day.
Very productive indeed...Love to see you already posted another CX-30 DIY thread...This is great info...Again, cool pics as well! (y)
  • Like
Reactions: rzc
... So, since I was in there already.... I went ahead and added the t-harness and installed the Evo One.
Since I had a dual zone proximity sensor, without the 4 to 3 pin wire, I decided to solder the wire directly to the pins.
I plan on testing this out this weekend and see how it goes.
Here's a pic of the Omega AU-94TM Proximity Sensor.
I dry fitted and tested it out and works great! It does the warn-away (2 beeps) and full alarm without any issues.
Below is the link... WARNING - LOWER YOUR DEVICE VOLUME BEFORE WATCHING IT.
I need to do the final install and adjust the sensitivity setting and lower it down a little.
