CX-5 Jack points, Pinchweld Heights, Bottlejacks and Pucks
I've got some of those plastic rhino ramps and the rubber grips on the bottom don't really hold them in place very well. I should figure out some way to stabilize them.
I bought the Black Widow ones also, I haven’t used it yet. When shopping, i watched a review where they wet a tshirt, layed it down and set the ramp on top of the wet shirt. It’s a good review of different brands. Still, these things scare the hell out of me. I’m going to pick up a daytona long reach floor jack anyway, to do tire rotation with my jack stands. Heres a link to the review
You can see the jack, stands, adapters, and ramps I use in this picture:
Hey, question. On your cx5t, do you use off road mode to use the ramps, any tips on getting the cx5 on the ramp without a slide or driving over the end?🤣 What’s the technique?
I use old vehicle rubber floor mats with grippy fingers for the carpet to stay in place… under my Rhino ramps. They never move on garage concrete.
I use second gear start on mine to creep up onto my ramps
On the cx5 rear, mazda lists the rear center jack point as the rear differential housing? Man, is that right? At least on the miata there’s a crossmember.
Correct on rear differential. I’ve always used that piece that hangs down
Good thread here
Nothing is needed but to simply drive up normally in first gear. They never slide on me.
For the AWD car it is the differential. There's a flat section protruding from the bottom:
The jack point hangs directly below the rear differential housing, just as it does on the MX.
It's different on the MX-5; there, it's not the differential housing itself but a crossmember, similar to the front.
It's more like the FWD CX-5. It's been a while since I looked at one though.
It's more like the FWD CX-5. it's been a while since I looked at one though.
Yeah, not exactly the same but in the exact same location. It's pretty clear where to place the jack.
These are very nicely made for how cheap they are!
Only one zonk from me though: the magnets cause them to rotate as they get close to the car, so you need to get your hands on them to align them on the jack or stand. I could live without the magnets as the CX-5 is covered in carpet and plastic and they don't really stay up there anyway.
Looks like someone copied the design and is selling them at Harbor Freight:
I will pick a couple up when they actually get them in stock.
Don’t forget to double check that the adapter left the rail when lowering the jack. Pretty sure I lost mine on a drive after a tire rotation that way, lol! I’d actually prefer they weren’t magnetic for that reason but that’s just me.
