2021 10-speaker Bose CX-5 Frequency Response Curves
Didn't know I wasn't the only REW user on Mazdas247 :)
You definitely don't want a flat "room" response; it will sound really bright because to do so you must increase the direct sound of the drivers well above flat. The sound you hear at your seat is a combination of direct and reflected sound, and those reflections are naturally attenuated.
That is a personal preference. I DO want flat in-room response. It makes the recordings sound more natural and a G and an E are reproduced as the artist played them, not one louder due to the speaker or EQ flaws. I do not hear brightness from flat response.
Oh, I think it's something like 99th percentile (AES papers in the 80's and mid-2000's) find the sloped in-room loudspeaker power response (all the speaker energy from all directions, summed) highly preferable to any other curve, including "flat power response", which the vast majority find highly irritating and EXTREMELY thin and shrill.
While REW and other windowed (synchronized FFT) measurement systems can isolate the axial response--what most people inadvertently are referring to-- our hearing is rather an integrating machine that perceives the power response. A basic RTA with a diffuse-field mic also (more or less) perceives the power response.
However, a simple RTA is highly subject to comb-filtering from off-axis enegy and difficult (but not imposisble) to provide an accurate power respoonse measurement.
That said, a speaker that has a flat axial response (as measured above, or in an anechoic environment) and a smooth (but not flat) off axis response--as measured on a turntable or in a typical enclosed space-- will have an excellent down-slope fitted power response and be perceived as excellent by the vast majority of the population with normal hearing.
My CX-5 is 2020 model, not a Bose 10-speaker version, but a 6-speaker version. Because I want to upgrade the audio equipment, I want to test the TAU output signal of the CX-5, not RTA, using surface pro4+REW, AUX-in connection, and using the sound card calibration method to test. It feels terrible.
Front audio signal:
Rear audio signal:
I'm about to finish up the upgrade in my wife's 2021 CX-9 with the 6 speaker. I'll be using the Kicker Keyloc to create a flat frequency response before it hits the Alpine DSP.
You should check those out. Pretty amazing piece, especially for the money
