Wind noise in CX-90 cabin…Anyone else?
Wind noise is likely an issue on all cars, depending on how fast they are going.
At what speed do you notice the wind noise in your CX-90? Do you have a roof rack or roof rails installed?
there will be wind noise around the A pillar depending on how strong the wind is and angles but other then that, no other wind noise that i know of.
I am noticing wind noise from the rear doors. Fine sand is also making its way into the cabin and on the floor between the rear seats and the doors.
The dust is from the rocker panel covers on the bottom of the doors and need to be cleaned out periodically when you wash your car.
So does it come off those covers and into the cab when I pull the door open?
Yes it does come into the cabin when you open and close the doors. The design is to keep the rocker panel dry and your clothes from getting wet or dirty, but the downside is the dust if it accumulates to much will get inside the car.
