Hello All,
I recently purchased a new 2023 CX-5 Select (non-turbo) in Houston, USA. The car currently has 150 miles on it. I noticed that when the AC is on, the rpm fluctuates between 500 and 750 at idle. That is, the rpm will fall from 750 to 500 and then go up to 750. I don't know what is causing the rpm to be unstable. In my previous car, the rpm was always stable at idle when the AC was on. Is it normal for rpm to fluctuate in the CX-5? If not, what should I do to fix it? Sorry, I am not knowledgeable when it comes to cars.
Thank you for your time.
Rick
Rick
