2013~2016 CX-5 Rear Diff and Transfer Case Fluid Change: Tools, Parts and Links
I know the rear diff says level surface which I guess I could do by skipping the ramps, but for the front transfer case is there any issue with using front ramps only and filling to fill plug level? I don’t really feel like trying to roll up on both front and rear ramps by myself with no spotter, I can never really tell how it’s going and using 2 sets of ramps makes me weary.
I don't see how you can get a proper oil level like that, unless you rolled it back down to a level surface, crawled underneath and checked it, then put the plug back in.
Yeah I figured it out, I have a driveway that slopes pretty close to the ramp incline so rear tires in the garage ramps on the driveway slope, drive forward and front tires elevate to the level of the rear tires which remain in the garage, lots more room under the front too!
View attachment 320045Yeah I figured it out, I have a driveway that slopes pretty close to the ramp incline so rear tires in the garage ramps on the driveway slope, drive forward and front tires elevate to the level of the rear tires which remain in the garage, lots more room under the front too!
ok, looks like an elaborate setup!
Looks like you have only one bottle of Mazda SG1 gear oil. And did you change the gear lube in the rear differential at the same time?
Yeah I had 2 bottles, did them both and still have 3/4 of a litre remaining
Great. Some trusted the capacity listed in owner’s manual and bought only one bottle of SG-1. It ended up they had to find an ride to got a second bottle at their local Mazda dealer for higher price.
Just a bump on doing this TSB if you have 13-16 AWD and cross in water or use underbody carwashes
Looks like an example here
Changed my rear diff fluid this morning. Last time was around 30k miles ago and in 2020.
Fluid was about halfway between new and dark. Only a very small amount of deposits on the magnet and no signs of other visible metals.
Instead of using a pump I just used some clear vinyl tubing I snaked through a hole in suspension arm and one of the Amsoil squeeze bottles to fill it up.
I forgot I had bought a whole bag of cheap crush washers years back.
Reminder to ensure your ‘13-‘16.5 has this retrofit vent for the rear differential on AWD models to avoid potential water intrusion into rear differential.
#RearDiffWaterIntrusion
Part showed up for rear diff water intrusion issue I posted in a few back here
Sorry... terrible pics... probably won't get to this until January though.
Not sure if everyone has read that TSB but the issue is
"The breather pipe grommet (A), located in the trunk, may be submerged in water that penetrated through the rear ABS wheel-speed sensor harness grommet (B) during a high pressure car wash. The water then enters the coupling unit (C) through the breather pipe (D). This creates rust inside the coupling unit, which causes internal wiring harness damage, setting the DTC and/or the coupling unit noise due to increased rotational resistance."
2013-2016 CX-5 AWD vehicles with VINs lower than JM3KE******837718 (produced before July 1, 2016)
View attachment 305515View attachment 305516View attachment 305517View attachment 305518
First I am hearing of this, thanks. Is it very difficult to replace?
It wasn’t hard to replace
