Mazda Connect Firmware 74.00.230A (now .324A)
Status
Not open for further replies.
Looks like there’s a new firmware, anyone try it yet?
74.00.230A
Changelog
***** MAZDA Firmware ALERT *****
from JUN 01, 2021
MAZDA (MZD) CONNECT, WHAT FIRMWARE DO I INSTALL..?
FOLLOW the .PDF INSTALLATION INSTRUCTIONS 100%.
'.up' Firmware used for All MAZDA-MZD CONNECT MODELS 2014-2021.
**NOT For first production CX-5 or Mazda 6 with TomTom Navigation**.
*NOT For MAZDA CX-30 or MX-30 or MAZDA 3 (BP) see the
"CONNECT II 2019~" Folder for their own '.kwi' firmware*.
***NOT For 2021 MAZDA CX-5 (KF) or MAZDA CX-9 (TC) see the
"CONNECT 1.5 from 2021~" Folder for their own 'kwi' firmware***.
BEFORE you START, Switch CAR OFF,
Then Remove Navigation 'SD Card' and
LEAVE the SD Card OUT of the Car until
the FINAL File is Installed.
Then Car OFF again, then Insert SD Card.
Then start car.
Navigation will work as normal when using CONNECT.
1. Your FIRST Install Procedure...
IF YOUR MAZDA has old FIRMWARE VERSION ON or BELOW 30.00.000
LIKE 23.00.000 or 25.00.150 or 28.00.300 or 29.00.100C
THEN YOU *MUST* UPDATE with Version Number 31.00.100A FIRST.
THIS IS A TWO (2) FILE INSTALLATION FOR YOUR REGION or COUNTRY.
31.00.100A-FAILSAFE.UP (First)
Then next Install
31.00.100A-REINSTALL.UP
Warning...!
DO NOT TURN OFF/ON or START ENGINE BETWEEN THIS
TWO FILE UPDATE, you INSTALL ONE after THE OTHER
DO NOT REMOVE USB FLASH DRIVE.
AFTER INSTALL RUN YOUR ''CONNECT'' IN CAR FOR
A FEW MINUTES,
THEN SHUTDOWN CAR FOR THE NEXT VERSION
TO INSTALL.
2. Your NEXT Install Procedure...
IF YOUR MAZDA HAS FIRMWARE VERSION ON or BELOW 59.00.560A
LIKE 31.00.100A or 41.00.000 or 51.00.351 or
55.00.650 or 56.00.513 or 59.00.502A
THEN YOU *MUST* UPDATE with Verion Number 70.00.100A FIRST.
70.00.100A-FAILSAFE.UP (First)
Then Install
70.00.100A-REINSTALL.UP
Warning...!
A FEW MINUTES,
THEN SHUTDOWN CAR FOR THE LAST FINAL VERSION
TO INSTALL.
3. Your FINAL Install Procedure is ONLY 1 (one) File now...
IF YOUR MAZDA HAS FIRMWARE VERSION ON or ABOVE 70.00.021A
LIKE 70.00.100A or 70.00.110 or or 70.00.150A or 70.00.335C or 70.00.367A
THEN YOU UPDATE to 74.00.230A for the LATEST FIRMWARE.
This is now a SINGLE FILE (1) ONLY INSTALLATION for
YOUR REGION or COUNTRY, MUST USE EITHER ONE of...
NA N_74.00.230A-UPDATE.UP (North America ONLY)
or
EU N_70.00.367A-UPDATE.UP (Europe/UK)
or
4A N_70.00.367A-UPDATE.UP (ADR, AU. NZ, ME, Asia)
THIS IS THE LATEST FIRMWARE CURRENTLY AVAILABLE.
INSTALLATION AS PER INSTRUCTIONS IN SERVER
''MAZDA FIRMWARE UPDATE PROCEDURE WORLDWIDE'' .Pdf
ALL 7x.00.xxxx FIRMWARE INCLUDES the Software for
CAR PLAY + ANDROID-AUTO....But...
For the CP/AA CONVERSION TO ACTUALLY WORK IN YOUR MAZDA
You MUST HAVE THE TWO ''GENUINE MAZDA PARTS'' INSTALLED
AFTER any 7X.00.XXXX is installed and or WORKING in YOUR CAR FIRST.
More Information on How to get CP/AA Working Do the Following..
OPEN THE ''-CARPLAY-ANDROIDAUTO INSTALL'' FOLDER IN
THIS SERVER ON HOW TO DO THE GENUINE CONVERSION.
THERE ARE NO SHORT CUTS or OTHER BRAND PARTS...NONE, SO DO NOT ASK.
YOU MUST PURCHASE AND INSTALL THE TWO GENUINE MAZDA PARTS, LAST.
YOU CAN NOT SEPARATE THIS CARPLAY and or ANDROID-AUTO
PACKAGE AS THEY ARE BOTH INSTALLED WITH all 7x.00.xxx FIRMWARE.
CARPLAY and ADROID-AUTO WILL NEVER WORK WITHOUT THE
TWO ''GENUINE MAZDA PARTS'' Finally INSTALLED Last...PERIOD.
WCP or Wireless Car Play is included in all 74.00.xxxx Firmware, BUT
You MUST aslo use a new 2021 CMU meant for WCP use price is over $999 USD.
If 74.00.230A is not in this Server for your Region it means a copy is not yet available
for Your Region or Country in the wild, yet.
Hi Crickey, can you please PM me this firmware as the link in the post is gone. Thank you.
I’m on 74.00.230 NA and with the iPhone and CarPlay disconnects very often. Does anyone else have this issue, and does .310 help with that? It’s my only complaint but it makes it unusable.
Well I am still have an issue when inserting the USB flash drive.
I am using two brands, 16MB Uno from Walmart and an older 4MB HP drive with both files loaded on both. Both drives are formatted to FAT32 with one at 4KB and the other to set to 8KB when not performing the quick format. When inserted, it goes out tries to read the drive with one progress dot or marker, stops, then displays "Wrong or Insufficient" files. Then it goes back to the bootup screen and tries again with the same result. What I am missing ?
Hello everyone, can @anyDude or someone else share firmware 74.00.230 for Europe?
Also, if someone has firmware 70.00.352b for Europe, I would be grateful if you share it.
there is no EU version released. I only obtained the NA version, that's the only one I could find and that is available. Several people have asked me for other region files now - I should have clarified in my post that it's NA only but everyone please stop asking me about other regions for v74. If you want something older I may be able to help but otherwise sorry
I sent you a DM but from now on everyone please reach out to me directly with a DM instead of just requesting on here
Guys, I think I have just obtained this new firmware 74.00.310A firmware that Hawke was talking about. I was able to guess the AWS direct download link based on previous link addresses for older files. If anyone is interested in trying it reach out to me and I can send it to you. I have no idea what the actual changes are though so if you are interested and apply the update, please let me know!
Hi anyDude, can you PM me the firmware please. I am with Mazda CX-5 Australia
People please, any linked 74.xx.xxx NA available here or anywhere else it's not for Europe or Australia or any other part of the world, it's North America only.
Read this: If you are in one of those regions and install 74.00.310 NA it's not possible to revert back not even dealer would help you.
Thank you MzdCX5👍What is the firmware version available for Australia? My current one is 70,00,335 4A N
I'm planning on upgrading from 70.00.367 NA to 74.00.310 NA at my next service visit. Mid-May. I've got a '19 GT and wondering if those with 74 are generally happy with it. Mixed reviews over within this thread.
Thread cleaned… ⚠️ Please remember we’re here to share and assist each other in a friendly and non-confrontational way. Being confrontational and or condescending will result in your account being permanently banned.
⚠️ Consider this post a final warning. Any further conflict and or confrontational posts will be removed and accounts may be permanently banned.
⚠️ Also, please remember to contact @anyDude directly (click username and “Start conversation”) as he requested and be sure to throughly read/search this thread before posting questions.
Now let’s get this thread back on track and topic, thank you.
Hi, can you please PM to me, thank you!
Status
