Mazda Connect Firmware 74.00.230A (now .324A)
Status
Not open for further replies.
Hi floks ! somebody know if the latest 74 version for N.A works for a Mazda CX-5 2018 with the actual version : 70.000.100 ?
Can you upgrade/update from 59.XX to 74 directly? I'm planning on getting the retrofit kit for my car so I can enable Carplay/AA without having to use "tweaks" for that. Any help wil be much appreciated.
no. upgrade from v59 to v70.100 first. then you can go to 70.367 or 74 directly after that
My 2015 Mazda3 currently has V55.00.750 NA N installed, reading the March 2020 Mazda Connect CMU Software Update Procedure doc linked from the OneDrive in this thread it says it's only for cars still using NA V55.00.650 or older.
"NOTE: If current software version is older than 55.00.650 like 33.00.100, 42.00.100 or 45, 52, 55.00.100 update first to 70.00.100A, then update to the 352B version. IF car is still on Stage 1 Firmware like 25.00.100, 26, 27, 28, 30.00.200 then MUST INSTALL 31.00.100A BEFORE Stage 2 of 70.00.100A."
It sounds like I should update to V70.00.100A first? Just want to confirm so that I don't brick my infotainment.
Thank you!
Thank you!
Yeah just update to 70-100A first then go to 70-367 and you should be fine
Hi, I am in Australia and have a 2017 CX-5 with firmware version 59.00.504 4A N. Just wondering what version I can update to and if I need to go through a number of different versions to get to the latest?
Appreciate any info.
Thanks
OneDrive
Firmware working Link.
hi amir, please help me about firmware update...
on my mazda 3 skyactive 2014 i have firmware 31.00.100
and i cant do anthying with mazda AIO tool... my mazda says i should update to 56 od bigger firmware... i see you have post link with the 70.000.376 can i update this fimware or should i do update with 56/59 ??
i read somewhere that i schould update firts 56 then bigger ??? why ??
Guys, I think I have just obtained this new firmware 74.00.310A firmware that Hawke was talking about. I was able to guess the AWS direct download link based on previous link addresses for older files. If anyone is interested in trying it reach out to me and I can send it to you. I have no idea what the actual changes are though so if you are interested and apply the update, please let me know!
Is this for 2021 and above MY or below?
These versions are for the cars with the older style MZD CMU headunits (the ones with the red theme), so yeah for below. The cars with the newer (black and white) systems use a completely different version numbering system. Just look at the version info on the system to see.
Could you share the link to 73.00.310 NAN I have the 74.00.230 version. Regards.
Status
