2013~2016 CX-5 High Pitch Whine
Mazda CX-5 Grand Touring
2016 CX-5 AWD - The whine only is noticeable when at speed. Maybe 30mph and up. It is not the brakes. Rotors and pads just changed all the way around. While doing this, I rotated and tried to twist the wheel while it was up in the air to test the wheel bearings. All good with the possible exception of the left rear and it was not convincing. I thought I "might" be able to feel a very slight vibration in the spring while rotating the wheel. Still whines. At 60+mph I shift to neutral, engine winds down but whine remains constant with no change. I have read somewhere that a bad torque-converter will sometimes whine.
Question I have is if it is the torque-converter, will it still whine when I shift into neutral or would it stop when in neutral at speed?
Thanks,
Greg
how many miles?
does it happen all the time?
Does it disappear at higher speeds?
See if you can be sure its not a wheel bearing.
Rear ones usually go first on my previous cars for unknown reason.
Mazda has a service bulletin for some cx5 2013-2016 and certain 2017-2018 models for whining noise from the transaxle above 10 mph.
depends on vehicle speed only
all types of driving - acceleration, steady speed or deceleration
does not depend on rpm, gear or atf temp.
Reason is a damaged bearing inside.
There is another bulletin but its for more for sqeeaks.
Hopefully its not that in your case but try to isolate all other options first.
how many miles?
Thanks for the reply. I looked up the TSB and it describes it to a "T". I might be screwed on getting this fixed on Mazda's dime. Warranty expired in 11/21. Will call the dealer and see if they can get approval from Mazda to do it as a warranty item anyhow. Never hurts to ask.
Thanks,
Greg
Hey @nelsongg, did you manage to get this fixed? If so, how did you end up getting it fixed?
I also have a 2016 CX-5 that’s no longer under warranty with the same symptoms.
What a coincidence, I'm going through this exact thing right now ( to a T) . Thought my wife's car had a bad wheel bearing 3 weeks ago replaced both front no change. A bunch of online research, half a dozen phone calls and now her car has been at mazda for 2 weeks now and we're currently waiting on mazda corporate to get back to us on whether or not they will help us. She has a 2016 cx5 touring with 56,xxx miles leased new then bought outright. There shouldn't be an issue with a 56k mile transmission.
Well it's been 2 weeks since I drove it and I've never heard a dog whistle but I could probably make that correlation. Just like the TSB states right after 10 mph it starts and doesn't stop. My final 18 mile trip to the dealer at highway speeds definitely had me nervous. On deceleration I do remember it better. I'll do my best, let's start with 2 concentric circles made of metal and they are rusty, maybe the outside circle got slightly egg shaped and as the inner circle rotates inside this new egg shape you can her a sloushy sounding metal grinding. In the rotation you can hear when it's hitting this same spot everytime both accelerating and slowing down but after maybe 40 mph it seemed to balance out and have less of the metaly grinding and more of like just a bad wheel bearing hum.
I have the same issue on a 2017 with 106,000 miles that I just purchased. It predominantly makes the sound in third gear as soon as it shifts out of third the noise goes away. I can't make it make the noise in fourth gear but when it shifts to fifth and you're decelerating at a low RPM it comes back. You can slightly hear it in lower gears but nowhere near is loud as third. I can also slightly hear it when in park or neutral and when I shift into drive it goes away. That would not make sense if it's that bearing going bad as it would not be spinning. I'm wondering if there's anything else that can cause that same whine. It also completely goes away at highway speed. Although I do have some road noise either from tires almost being down to wear marks or a wheel bearing sound. I made some videos.
