Hello all.
Anyone have a copy of 74.00.230A that they can PM me?
We are based in UK. Europe.
Thanks in advance
For which country is that update? It is available for Europe,UK.
this is for ADR, AU, NZ, ME, AsiaFor which country is that update? It is available for Europe,UK.
Hello @xbud , were you able to resolve the validation error for 70.00.367A? I am facing the same issue while updating from 70.00.100A North American version. I was on 50.xx.xx and successfully updated to 70.00.100A.Tried to update to 70.00.367A from 70.00.335 this evening and received a "Error Validation Check" Went through all the steps again by starting over with a new USB (reformatted) and fresh download re-followed the instructions and the same error......not sure what happened.
You may already know, but CarPlay hardware installation works just fine with 100A, no need to update firmware further if getting CarPlay to work is the objective.I am facing the same issue while updating from 70.00.100A North American version. I was on 50.xx.xx and successfully updated to 70.00.100A.
Main intention for firmware update is to get Apple carplay installed
I wasnāt aware that was a thing.. is that a thing? You might be on the bleeding edge. I guess first place to start (without having hw in front of you) would be comparing pinouts and unit dimensions. Your 2018 deets are pretty easy to find online. Not sure on 2021 though. If it were me, Iād call dealer, get part numbers for CMU and display. If they have one in stock go there in person on a slow day and see if theyāll pull it for you, take some measurements and pictures, then do a stare and compare to get an idea of LOE. Alternative might be to get on a list at a salvage yard, being winter and all. Unless you have a *really* good friend with a ā21 that will let you disassemble. Make a video for YouTube, cuz unless my google-fu deceives me, thereās not much out there on 2021 disassembly yet.upgrade to the 2021 CMU
It can be done, and wiring was im not worried as much as I am of retrofitting the actual unit into the dashboard without cutting etc.I wasnāt aware that was a thing.. is that a thing? You might be on the bleeding edge. I guess first place to start (without having hw in front of you) would be comparing pinouts and unit dimensions. Your 2018 deets are pretty easy to find online. Not sure on 2021 though. If it were me, Iād call dealer, get part numbers for CMU and display. If they have one in stock go there in person on a slow day and see if theyāll pull it for you, take some measurements and pictures, then do a stare and compare to get an idea of LOE. Alternative might be to get on a list at a salvage yard, being winter and all. Unless you have a *really* good friend with a ā21 that will let you disassemble. Make a video for YouTube, cuz unless my google-fu deceives me, thereās not much out there on 2021 disassembly yet.
