I'd rather not do that. The less things to see in the vehicle the better.Do you want to install the display in/under the dash and leave it connected? I have an Ultragauge and it reads codes,etc; plus it displays various engine parameters as you drive.
I just upgraded to a better, moderately priced scanner a few months ago. Wanting just the basics without ABS,SRS, SAE etc., I chose the Foxwell NT301 after a bit of internet research including youtube videos. Amazon had it (and still does using the 20% off coupon) at a good price and offered 50% off the Foxwell hard case if both purchased together, so the case only cost $8 ( it's still offered, check the promotions) and the scanner about $53. I also purchased a 5 ft extension cable for $9 (it fits in the case easily and is also on promotion) so I can stand in front of the engine with it.
It's right on the amazon product page. Check the box right under you save $3.50 at the top.Where does one find the 20% off coupon?
Before I bought my CX-5, I took my Foxwell NT520 Pro along, and with the owners permission, scanned the car. The only code it found was for a faulty Bluetooth module in the radio. Yeah, it even reads that!
The owner said, "Yeah, how did you know that? Sorry I forgot to tell you that, the BT hasn't worked in a couple of years, and I honestly forgot about mentioning it." She cut the price of the car by $250. Pretty much, it paid for itself right then and there.![]()
Awesome! A $250 discount. You did well. Since it's been about 1-1/2 months since I fooled with it, I just now got back inside from plugging in the scanner. Well, the 'handshake' (tried 3 times) takes about 6 seconds and it's connected and shows 'homepage' screen of options. Since there are no codes I viewed live data (three times) and it is not slow changing to the next screens (there were 43 PIDS).Before I bought my CX-5, I took my Foxwell NT520 Pro along, and with the owners permission, scanned the car. The only code it found was for a faulty Bluetooth module in the radio. Yeah, it even reads that!
Would a device like this be able to set the EPB for pad replacement?I wonder if this one on Amazon might be good?
Autel MaxiCheck Pro for ABS Brake Auto Bleeding OBD2 Scan Diagnostic Tool, with SRS Airbag, Oil Reset, SAS, EPB, BMS for Specific Vehicles, Software Lifelong Free Update, NOT Support All Cars
amazon.com/dp/B07P621KR1
Yikes! Only $2,800 U.S. dollars. Pass. I'm just a DIY. As Joe Biden would say: Come on, man.
Looks like $198.60 on my computer on the US site.
mythinkcar.com
