Might be time to let that one go and bring up a new one from Cardone.
I don't just need a Cardone caliper, I need a complete Car donated.
She's rotting.
Sure is. Goes to the market and the gym. Thats its life!I bet it still makes a GREAT grocery getter!!
Do you still drive it or is that one your parts car now?She doesn't pollute though and doesn't burn a drop of oil.
That was 10 years ago when they sniffed the tailpipe, then they plugged into the OBDII port, now they don't even check.
But I still don't burn oil...
Looks like your Gas Cap Pressure Test did great!!The mechanic came out with a big smile on his face and said that he thought his sniffing machine was broken.
He was getting readings of zero.
He had to run the test twice to finally get a reading.
The air coming out my tailpipe was cleaner than the air going in the intake.
Ok how'd you rig that??I was allowed 150 PPM of hydrocarbons idling at the curb.
I had none.
I passed. Lol![]()
Looks like your Gas Cap Pressure Test did great!!![]()
Inquiring minds want to know...
Isn't P5 Love grand...Yeah, that's my daily driver.
She's rotting, but still runs like a top...
The dogs are on their way...I wonder if I could still get a sniff test done ?
I'm curious to know what it's like now.
I would love to see what mine does for actual emissions. In CT all that matters is having a functioning CEL and having the car not actively throw a code (or have a recent clearing). I did my emissions testing again a few weeks back. On the way to the shop I threw a CEL. Cleared it, drove a few days until my blue driver said I was in the clear. Went and got the thumbs up. A week later CEL back onI wonder if I could still get a sniff test done ?
I did my emissions testing again a few weeks back. On the way to the shop I threw a CEL. Cleared it, drove a few days until my blue driver said I was in the clear. Went and got the thumbs up. A week later CEL back on. Heres to another 2 years! If the car doesnt become one with the earth by then.
Yeah, that's what they started doing here the next time I went for the test (two years later).
Now they don't test anymore.
What was your code?
It could be a simple and cheap fix that may help with drive ability, fuel economy and reduce your contribution towards killing the world. Lol
Strangely enough, you could completely remove your main cat and not throw a code.
You could potentially polute like crazy and your ECU wouldn't know.
There is no sensor after the main cat.
Oh I have been polluting for years since I removed the pre cat for an obx header prob 10 years ago. Code is for o2 sensor wiring I believe. Only will come on if the car sits for a while not driven, or if it is driven after a heavy rain. Still getting 27mpg city somehow. Every time i turn the key I am shocked it wants to keep going. Just keeping it alive long enough to be a backup, backup car
(unless you are burning a ton of oil which can overwhelm even your main cat and burn it out too.
Then you really start to pollute and your car will run like s***.)
I believe I had this issue last year when my radiator cap failed. Parked my car after a drive and heard boiling over at the expansion tank, dumping coolant out of it. Replaced it and all has been well sinceQuestion: what would cause the overflow tank to completely overfill after a drive, when it was at the mid-range of the tank when the engine was cold?
Hoping this is not timing belt/ water pump time.
Overfill or Overflow?Question: what would cause the overflow tank to completely overfill after a drive, when it was at the mid-range of the tank when the engine was cold?
Agree.The middle of the tank is too high when its cold. The low line is like 2 or 3 fingers from the bottom. Once mine puked out the overfill tube on the overflow. I opened the rad cap and filled it then drained the overflow down to the cold mark. It never did it again. I think it had too much in the tank and when i drove it it just overfilled when it warmed up. Try that and see if it works.
White steam/smoke from the tailpipe/coolant level loss might also be an indicator of a head gasket water leak.I had a honda long ago that also did that but the cause of that was a bad head gasket. The temp shot up and fluid came gushing out. Hopefully this is not your issue
Yup - radiator cap valve can go bad for sure and let coolant blow right on through to the coolant tank.I believe I had this issue last year when my radiator cap failed. Parked my car after a drive and heard boiling over at the expansion tank, dumping coolant out of it. Replaced it and all has been well since
