Speaking of oil and oil filters...
Yesterday morning, I went to replace the P5's knock sensor and before jacking up the car to do the sensor swap, I decided I should check the motor oil to see if the car might be using oil after I changed it about a month ago with about somewhere around 500-600 miles on it.
When I checked the oil level (with my "low profile" broken ring dipstick) it was right at the full mark (I might have used an ounce or two of oil at best as initially the oil level was slightly over-full by a couple of ounces (I had added some Seafoam to it).
While looking to access the knock sensor to see if I could get something on it to remove it (ended up using 24mm open-end wrench), I (reluctantly) saw that I had to remove the oil filter among other things.
When I took the oil filter off, I was expecting oil to pour out of it and run down my arm (the front end of the car was up on jack stands) and was surprised to see that the filter looked totally dry inside except for what little oil I rubbed on the filter's o-ring when initially installing it.
Initially, besides lubing the filter's o-ring, I pre-filled the filter with some oil (a few ounces) when first installing it about a month ago.
When removing the filter, it did feel as it had some weight or "heft" to it like the filter media had soaked some oil into it.
The last time I drove the car was the previous day so it seems odd that inside the filter appeared pretty-much bone dry.
The photos below are taken after removing the filter and tipping the filter upside down to see if anything would drain from it into a plastic container.
I wish I had taken one of the filter right after removing it.
As you can see, only a tiny bit of oil drained from it (maybe a teaspoon full) during the time I was finishing the installation of the knock sensor (at least 30 minutes).
When I bought it, the filter showed it fit the 2003 P5 2.0l when I bought it from Advance Parts store.
Anyone else notice a dry appearing oil filter when changing their oil?
View attachment 302651View attachment 302652
