2012 Mazda6 Power Connectors have no power
Our 2012 Mazda6 I Sport no longer has power in either power outlets, both by shifter or in arm wrest. I have checked and verified the fuses in the car and under the hood as good. I pulled the center console apart and check wiring. I used a volt meter to check for power on the power leads with the ignition on. I wonder if anyone knows if there is a power relay that supplies power for both outlets. At this point i am considering a re-wire of them both to a new empty slot on the fuse panel. Any ideas?
