Online Mazda parts.
There's all kinds of OEM Mazda suppliers on line, some are regular Mazda dealerships.
You could probably order them through your local Mazda dealership but you would probably get a better price online.
From what I remember, the aftermarket ones would start to fail when they got hot like in stop and go traffic.
The clutch would start to squeak/crunch and sometimes the clutch pedal would go right to the floor when the seals failed.
Ouch, these are a pretty penny, plus then I'd have to return the kit I bought. But at the same time, I'm spending $600 on labor.....
Yeah, it's a tough call.
The problems with the aftermarket stuff was a bunch of years ago, the quality may have improved if there was a lot of problems with them.
A failed clutch cylinder can be dangerous and leave you stranded, then you'd need a tow and have to replace the clutch cylinders again.
And I need my car to be reliable because I just got laid off 3 weeks ago and I'm looking for work....but at the same time I'm already $800 into the whole ordeal....ugh, I hate this.
Your clutch cylinders may still be fine.
You may be able to just flush/bleed them and you're good to go.
Your mechanic should be able to give his opinion.
It depends on how your clutch failed.
It doesn't sound like a clutch cylinder issue.
They have 125k miles on them. I'm sure I should be replacing them by now anyways. Its just a lot to take in at the same time.
The clutch cylinders aren't really a wear item, and are kind of separate from the clutch itself.
If your clutch pedal wasn't squeaking or felt crunchy or went to the floor and stayed there, then they are still probably fine.
You could postpone replacement until you're better able to deal with it.
It would suck to put new ones on that fail in a couple of months.
You can also buy the seal kits and rebuild your cylinders.
(You shouldn't need the pistons, just the seals.)
If your clutch pedal wasn't squeaking or felt crunchy or went to the floor and stayed there then they are still probably fine.
It is squeaking. It's also making a loud whine when I slip the clutch. To top it off, it's making a rattle on neutral and also when slipping the clutch in 1st and shifting to 2nd. After that, theres no more noise.
If the clutch cylinders are squeaking, they would squeak every time you push the clutch, and the sound would follow the movement of your clutch pedal.
Your noises may all be from the failed clutch.
Does your clutch pedal squeak when the engine is off?
Does it feel smooth?
It squeaked for a while, but it went away. However, when the rattle came, the squeak came back, and yes, it does squeak with the engine off.
Well, you may be fine with the clutch cylinders that you ordered.
The only other thing I remember is that sometimes the squeaking is coming from where the end of the slave cylinder connects to that fork thing inside the transmission.
A dab of grease stops the squeaking.
Or some grease or spray oil on the clutch pedal pivot and its connection point inside the car.
Those squeaks and fixes have nothing to do with failing clutch cylinders.
Failed clutch cylinders usually mean you have to pump the clutch pedal to get it to work, or the pedal just stays on the floor when you push it.
That's caused by failed seals in the cylinders.
I've had difficulties going into reverse, but that's about It.
Yeah, that's different.
We all have that problem.
There's a special gear or pin inside the transmission that prevents the gearbox from going into reverse unless the wheels are stopped.
I just let the clutch out and try again, sometimes it takes a couple of tries.
(I think it's for novice drivers that think "R" stands for "race" and try to go into "R" after 5th gear. Lol)
Swap end links Saturday. Replaced stock with Mood Ford Escape end links. Much beefier and with zirk fittings to boot. Stock ones are worn and boots torn off. Unfortunately, this was not the source of the clunk I've been haunting.
@dorihachigo nice work on those swaybar links! They look miles better than the oem links. Check your lower control arm bushes and swaybar mounts for wear, that's where my clunk was hiding :)
Thank you, I am planning to install new control arms along with struts, tops, and lowering springs soon. Outer tie rod could could use some replacing as well.
I lifted my protege5 with coilovers and I’m running some 215 60 r16 kinda a/s tires and it looks awesome and doesn’t rub at all. Oh and I have like 10 inches of ground clearance now.
My stock ride height P5 that scrapes on my steep a** driveway is jealous! 🤣
