Happy holidays everyone!
The car is running! Figured out the timing issues and it turns out the fuel calc was waaay out, it starts and runs now!
BUT
There's a massive vacuum leak somewhere so it idles at about 1600rpm, I can block the throttle body with a bit of wood and it doesn't die, and it's not making any amount of difference with the SC on or off. I've checked the IAC Valve, EGR valve, brake booster and all the vacuum lines I could find with no luck. The last thing I can think of is that the whole manifold isn't seated right or the manifold is cracked somewhere
SO
The intake manifold is off, all the lines are getting replaced and clamped and new gaskets are going in. While it's off I'm tidying up and wrapping all the wiring as well as that all worked as intended!
All the gaskets seem Ok, there's no tears or lumps in anything, although the gasket where the manifold splits hasn't stuck in some parts (on the thin triangle sections below) so maybe it's slightly warped?
I'll run a straight edge over it and maybe lap both surfaces just for good luck
If anyone has any ideas on where there might be a leak, let me know!
Also, from the drivers seat the supercharger whine is at least as loud as the exhaust
