I have pulled every hose back around the filler tubes. When inspecting the CdCv I was able to get air to go in both directions? Should this be closed one way when the car is off? Haven't tested it, but I imagine that it would cause a large leak detection if it's always open and should be closed during operation. Still doesn't explain why I can't put gas into it if it were open not impeding air flow.
My check valve was fine. Air went in both directions but vacuum showed a closed path in one direction, no debris.
The filter canister was almost dry. It barely gave a few drops with air blown in repeated times.
The hose going to the charcoal canister didn't allow air in. When I blew into it, the air came back, slow hissing. I did that a few times and got a few drops of gas?
Any ideas?
The car runs fine. No noticeable drop in mpg. The gas fill up issue is very annoying.
Any ideas?
