Yes, I have CS springs.
I have replaced all four Konis this weekend, but I had a problem at the end, at the rear driver side.
When I was screwing in the bottom knuckle bolt(nut is captive) it wasn't raised the suspension properly(did not pay attention) and the bolt went in a bit crooked. It messed up the nut's thread.
Luckily, I'm a machinist and I will take care of it tomorrow.
Lesson learned, take out the nut and make sure that the end of the bolt is centered in the cutout hole, then insert the nut and start wrenching on the bolt.
The rears, I have adjusted 1 turn. I will adjust tomorrow the front ones, maybe 1-1/2 turn and I will see how they are. My car is much more lowered(3-1/4"), then the H&R ones. Should I set the adjustment stiffer, or softer?
