The two inner nuts, from the rear spoiler were off again.
I have reinstall them and tightened them again very well.
	Rear spoiler on the CX-5? What am I missing?The two inner nuts, from the rear spoiler were off again.
The piece sticking off the rear hatch door, above the window.Rear spoiler on the CX-5? What am I missing?
Lol it would be cheaper to buy coilovers than keep using the springs. All I see is bad press about those springs, had a local ftiend replace hers with bc racing due to poor ride quality/bottoming out. CX racing hs a set starting at like 480. You're gonna trash new components with them. I'd purchase autoexe outer tie rod ends btw since you are lowered.Purchased Koni Yellow struts.
It seems like, I need to rebuild my whole suspension.
I have just replaced all my brake pads/discs. I have noticed that my tie rod ends and lower ball joints rubber boots are all cracked open. I can't test my struts/shocks, but to me it feels like they are very bad. Car became much more bouncier than it used to be.
I will be buying and replacing parts in stages.
This time around, I will be installing a set of camber bolts as well, for easier camber adjustment.
I'm on CS springs and last time, they had a very hard time bringing the camber angle in spec. It is just barely in the green zone, on the printout. They had to use some kind of airbag, to push on suspension components, before tightening down the bolts.
Anybody has this setup? CS springs with Koni Yellow struts/shocks? By the way, they are 20% discounted now, at Tirerack.
I see, thank you.The piece sticking off the rear hatch door, above the window.
And you cleaned up mother-in-law’s CX-5!Oil change and tire rotation for my mother in laws ‘17 GT. Followed it up with a thorough detailing of the interior and a quick wash of the exterior as an early Mother’s Day surprise. Her large dog sheds his needle like hairs everywhere so it took a bit.
I’m really liking the Meguiars leather cleaner and conditioner for her car. She doesn’t have time to take care of her vehicle so I’m glad I was able to clean the seats up before anything crazy happened. Looks like new!
Ordered Koni Yellows(they are 20% off, at tirerack) and camber bolts. CS springs with Konis. Anybody has this setup?
 ). It occurred to me that I need to get my snow tires taken off.
