- Central Virginia
- 2019 CX-5 Reserve
You could always try to start the carIs there a cheap McGyver way to test the battery?
You could always try to start the car![]()
I was gonna recommend the old 9 v battery test, but putting your tongue across a 550CCA 12v battery would not likely be something you'd live to tell the grand kids about. Of course, you'd have to be Gene Simmons in order to do it in the first place...Brilliant!!! That plan should work 100% of the time and when it doesn't...well there you go.
The sad thing is if you searched You Tube for that, you'd likely get 25 hits.was gonna suggest licking a thumb & touching the "-" post, then licking the "+" post. But that might cause a spark and ignite all the alcohol he'd have to of been drinking.
Yup.The Solar BA7 has worked great for me for so many years. Couple of times when it showed the battery is bad or borderline, I got it confirmed by the auto store free testing and the results were same. i.e. the battery is on the last leg. Is it worth $50. That depends. When I was single I used to drive till the car did not start and then replaced the battery. With small kids in the picture this is one area I find it is not worth saving a few $.
