Wanting to do a coolant change.
Location of Block Drain plug and can I reach it?
Other plan-
Remove thermostat and leave radiator drain open while idleing the vehicle with garden hose in. Let it drain and fill with distilled water and drain 4 or 5 times. this will leave it with mostly nothing but distilled water in the block then fill up with concentrate.
So the question becomes if you simply drain the system at the radiator what percentage of the entire system is drained? If I were to have the block fill of disitlled water then topped off with straight AF what would my ratio end up being?
Considering this fluid in full strength
RAVENOL J4D2092 Coolant Antifreeze - HJC Hybrid Japanese Coolant Protect FL22 Concentrate (5 Liter)
https://www.amazon.com (commissions earned)
Any other fully compatable FL-22 coolant that can be recommended?
Is there a previpous thread on full coolant flush change on the 2.5L? I find the search function to be smarter than me. Can't seem to narrow down the results.
Other plan-
