Hi everyone
To keep the manual a.c. running please let me know what I need to do? And how often you need to do the a.c. maintenance please. Thanks
Should never have to do that unless it's leaking.Felixd who posts a lot of helpful How To's posted a video on how to clean the AC fan blower. Something I want to do soon.
Cleaning AC Fan Blower
Outside of that, top off on the refrigerant if needed?
In addition to installing a new cabin air filter it helps to spray the a/c condenser down and get the road grime off for better cooling.I spray it down every time I go to the self serve car wash.It also helps to clean the radiator which is mounted right behind it.My a/c was working great this past week with the 97* days and high humidity.
I actually use an AC coil cleaner. Same one I use for my AC unit in my Attic and outside. It breaks down grime but wont harm aluminum. Otherwise use a garden hose but using min to med pressure only.
I use this product diluted in a gallon of water. I use a pump spray like one used for weeds. Spray on car radiator and condendsor thingy through the car's grille. https://www.amazon.com (commissions earned)
Leave for a few minutes then hose off.
At home, I spray this on my AC unit's Evaporator coils to keep it clean from dust and grime.
Hi everyone
Interesting. Thank you!
Run it 10 minutes per month minimum to keep it internally lubricated, and change filter on schedule.
