I'd wager that 95% of the population doesn't even know what the tachometer is showing, let alone understand what RPM is or what's required to have the engine go into limp mode. They'd know what "floor it until you're scared" means, but that's about it.
TLDR, asking someone to hold revs or keep above a certain RPM for a certain amount of time is like nerdy tech jibberish.
Mazda's fix appears to just prevent limp mode from occurring during a lean condition (likely just reduces power instead) because, the same people I described above, won't ever notice. Visually inspecting every Cx5 and replacing entire engines might bankrupt Mazda. Just reduce power (or ignore) for the 0.01% of the population who would ever encounter this lean condition instead of triggering a potentially dangerous limp mode. You now have your most cost effective "fix". Problem solved.
Fair point overall for the RPM. However I'd counter and say that anyone on a forum for a cx5 might already be in the nerdy crowd and could hold a RPM lol.
As far as the limp mode, PCM, rocker arm. It does seem as though Mazda took the approach of, there aren't any rocker arms that would have fallen off bc we would've already heard about it. So therefore any cars coming in for the recall are still OK. Not great logic but probably defend-able in court if it ever went that far.
		 In a near 4k lb vehicle, 187hp is already slow.
