Tire Pressure Monitoring on a 2016
davenoh
2016 Mazda 6
Can someone please confirm the 2016 Mazda6 uses the ABS wheel speed sensors to indirectly monitor tire pressure?
I'm planning to have the wheels powder coated and may remove the tires myself. I don't want to damage the TPMS modules if they exist. From the owner's manual and looks of the valve stems, it sure seems there are no pressure modules.
Thx
All cars sold in the US are mandated by the government since 2007 to have TPMS.
Yep. But that doesn't answer the question on whether there is a pressure sensor or it utilizes the ABS sensors. The ABS sensor method works by measuring the tire rotations per minute. If air pressure changes, the number or RPM of the wheel will change and provide an alert.
Just remove them, not familiar with Gen 3 6s but every TPMS sensor I've dealt with was in the wheel and you just loosen up the nut holding them on and slide them out. If you don't want to have a tire place do it for you as you got to have the tires removed any ways.
Sorry, late to the party but you probably already know answer, no sensor in wheel...
Abs module/speed sensor reads tpms
Mazda went back to in-wheel monitoring from 2017+.
For 2016 and earlier models, ABS sensors are used.
The latter gives more false alarms, but mine has been OK since new.
I got a '16 Mazda6 and '17 CX5. The difference begins at '17.
Check your OM.
