In 15, they had Smart City Brake? It's a first that I hear that.
i believe if you lower it consistently all around should be ok, this topic was also talked about on the mazda 3 forum,
basically you do not want to reduce the rake angle.
 ). You get a 1.25" drop in the front and 1.75" in the rear which essentially levels the vehicle. Have the headlights adjusted after the install.
