How do you find your CX-5 highway acceleration to be?
Faster? No. Feel faster? Subjective. ��
Mainly I'm concerned about getting around someone on the freeway, not teh feelz, so this one I think is more important to view objectively vs. subjectively, because losing...subjectively AND objectively sucks.
Try "squeezing" the pedal [all the way to the floor] rather than stomping. Just move your foot a little slower, and see if that makes a difference. It's counterintuitive, but it works for me.
I will give that a try next time. I just figured since everything is electronic, when WOT was achieved this thing would go like the wind. You know, electronic response and all.
Mine does. Maybe you spun the tires a touch and got t he timing pulled? maybe it was at the bottom of 2nd instead of hitting 1st?
Honestly, if you floored it and it did not basically go to redline fast and move the car, you might have an issue. I assume you went through the click pedal?
Modes? We don't need no stinking modes..(nor do we have them)) I 'manually' shift both my cars almost exclusively..control enthusiast...but unob's right on this one..all "sport" mode does in the CX-5 is quicken throttle response and hold gears longer- too touchy imo from my somewhat brief sampling
Sport mode in my 18 x3 is indeed sport mode. The engine transmission have distinct map changes
Sport mode in my *18 x3 is indeed sport mode. The engine transmission have distinct map changes
That's different/superior to the CX-5's how? My X1 has it too its rubbish. Your X3s maybe a bit smarter maybe apportions more torque rearward, etc but short of that and/or suspension/bush stiffening of higher end examples I don't see the point. 3 pedals and RWD- the best (and only true) sport modes are ones that can't be turned off:)
That's different/superior to the CX-5's how? My X1 has it too its rubbish. Your X3s maybe a bit smarter maybe apportions more torque rearward, etc but short of that and/or suspension/bush stiffening of higher end examples I don't see the point. 3 pedals and RWD- the best sport modes are ones that can't be turned off:)
There is no point. It*s still garbage, although it does adjust the power steering and body roll some...Either give the car a boost in power in *sport mode*, or leave it out and/or change the name of it...
Only real sport mode is an unfortunate dying breed, a true manual with a clutch pedal (as stated)...
On other brands it does from memory regarding faster acceleration.
Nope...
Funny thing is, for best acceleration, you*d actually want the softer ride of eco mode, and the better shift points of sport mode, hence them cancelling each other out basically. Now granted, the Bimmer sport mode is better than the Mazda because it adjust the power steering some, but it still does nada for performance and acceleration, and the adjusted ride isn*t worth it for most situations.
Nope...
(hmm) - Merc and BMW used to do it...
