Do you have a close-up picture on the back side (magnet) of OEM speaker so that we can read the imprint on specs and part #?
OEM non-Bose 6" door speaker is a full-range dual-cone speaker and your new speaker is a "woofer". I hope you feel no loss on high notes for your hearing preference.
No detailed pic - didn't care enough about it to take one. It says 25W 4Ohm made in Thailand.
In the OEM system with the tweeters the door speakers are full range, but the highs are handled by the OEM tweeter which is ran in parallel. Basically a cheap add on. In this configuration the highs are intended to be coming from the tweeter. Dual cone is the absolute cheapest you can get for a speaker and bare minimum in terms of performance.
I replaced the entire front speaker system with a component set - that being a pair of matched tweeters and woofers with a much higher quality and finely tuned crossover for the front speaker system.
I have lost no performance at all - just a drastic improvement. The new front speaker set has made a world of a difference, but this thread is about the pressure sensor in the doors and how the speaker works with that system. I posted my installation method as it retains the inner door seal just as good as OEM so as not to compromise the system which Anchorman has (thankfully) given us the heads up on.
