Wanted to share an extremely helpful resource not just for our cars, but other Mazda and Ford vehicles.
FORScan Lite for iOS, and Android, is a gem I stumbled across a couple months ago while looking for an app to match my ELM327 WiFi scanner.
Found this app extremity helpful in diagnosing a bad ECT as I was able to directly access the sensor voltage PID. Also, I was able to access the cooling fan PIDs to see if they were being commanded ON/OFF by the ECU.
Furthermore, I can also test IAC valve and monitor: alternator output voltage and other sensor voltages such as MAP, MAF.
Oh...and I can also access ABS codes.
I don’t know if Torque for Android can do this too but this app is a hella of a lot better and cheaper than other basic OBD II apps.
