Do this to see if your speedo is working.
And get your codes read.
Apparently auto zone does it for free if you haven't gotten the ELM327 yet.
Airbag light is off for now. As I was trying to test the horn because I’ve never used it, I must’ve shifted some wires or something because the light is now off. Final problem is the damn speedo and the CEL.
could this also be causing the speedo to not work? Because the horn and cruise control don’t work and it points to the clokcspring like you said.You'll probably have to replace your clock spring some time in the near future. They can have an intermittent break in the wiring of the clock spring (or some call it a spiral cable) and cause what you're seeing. It can also cause the horn, cruise control, or any other buttons on the steering wheel to not function or function intermittently.
...The speedo not working MIGHT also be causing the cruise control to not work if the speed sensor is not hooked up correctly at the trans.
I haven’t in fact and I’m lagging on it. Imma get around to checking everything today and checking the continuityHave you done this yet ??
You need to find out if your speedo gauge is working.
It just takes a few minutes.
Did it real quick and I went through all of the systems and 12 was the one that checked the speedo. It bounced all the way to max then back to like mid way and stayed there. I take it the gauge is fineIt's easy dude.. Just do it...
I did it just for fun..
(all my gauges are working properly !!)
Do you have an ABS light come on when you first start your car ?? For like six seconds or so ??
So,.. Just to verify,.. Look for this under the hood...
If you don't have ABS then you need to use the signal from your speedo gear located in the transmission.
If your engine came out of a car with ABS then your trans. doesn't have the gear. Then (as far as I remember) you have to remove your transmission, open it up, and install the gear. You may need to drill a hole for it too ?? Big PITA.
Your transmission may already have the gear, then you just need to connect up to it.
I can't seem to find much info on the VSS in the service manual at least for a manual transmission without ABS.
