Working as a snotty nosed kid security guard, guarding cars straight from the boat during graveyard shift...took my share of parking lot redline joyrides in brand new s2000's still with protective stickers on themDidn't put no more than 1 mile on them so nobody knew!!
They sell on Ebay, for Kenwood units as well. Is the same thing as for cell phones, just bigger.
I should install one of these to my Kenwood, since it has a shiny glass surface.
Cool. Don't see the point of one, but cool. LOL
+1
Makes sense on a phone or tablet that might be dropped or easily scratched, but on the dashboard...?
Most of the wear near my screen is on the plastic surface directly under it.
So you have rust problem on grounding of your CX-5 even in San Antonio?Went to clean the +/- terminals on my horns and put some battery terminal goop on the them and I found that the ground wire to one of my horns had split. The wire corroded to the point it came apart (1 little piece of rubber was holding it together). So I fixed that and added an additional ground to the loop to ensure max volume on the horns.
not rust, but (green) patina from the water and car wash etc getting on them and just dirt in generalSo you have rust problem on grounding of your CX-5 even in San Antonio?
Speaking of which, it is absolutely filthy under my hood. Is there a right way to clean it?not rust, but (green) patina from the water and car wash etc getting on them and just dirt in general
We used to steamclean them.Speaking of which, it is absolutely filthy under my hood. Is there a right way to clean it?
How do you steam clean an engine.
I just wash what I can with rags to whatever I can reach. In the old days you could wrap the carb and alternator and hose it out.
