Greetings my fellow CX-5 owners..... any ideas on how I can retrofit the OEM Bluetooth function on a 2014 model (need a new Bluetooth module and steering wheel answer and end buttons)
Plug it into the USB port and AUX port in the center console and you're good to go. Sound quality is excellent. If you want to get fancy you can run the cables inside the center console.
I use the Anker one in my 2013 and it works well. I did get a ground loop isolator as I found there could be some electrical noise at times and that solution worked well. The only thing (as many reviews have noted) is that the cord is too short if you want to mount on the dash.
