2017 CX-5 Pics Thread
The headlights are extremely good. It puts you up with the top of the range anything else boys when they refuse to dip!
I noticed that too. [emoji16] I tried adjusting it to slightly lower the beam but it seem to have a mind of its own. [emoji3]
You cant adjust the main beam if you have ALH, that is controlled by the headlight control unit and the camera in the windscreen. There are initial settings for if example the headlight was damaged in an accident.
You can’t adjust the main beam if you have ALH, that is controlled by the headlight control unit and the camera in the windscreen. There are initial settings for if example the headlight was damaged in an accident.
Great. Where were you when I posted that issue.
[emoji16]
Joke diesel master anchorman. [emoji16] I only learned about that after 2 attempts. And that 2nd attempt took me a thousand turns!!!
