Check Your Coolant Level
It’s very clear to me that he was being sarcastic, and not in a constructive manner at all.
The memes are just getting boring by this point.
lol Don't get your panties wadded up. Constructive?? YOU'RE the one who keeps starting threads that spread misinformation and/or are copy and pasted from Wikipedia.
Just loosen up a little Natey. People are allowed to have opinions and logically backed up theories.
As for the memes, most of them arent that good.
lol. Post count +1, huh? You're on a roll. (hah) "Logically backed-up theories"? That's one way to put it.
Here's some actual info:
If you're using a Glycol based (green) coolant and not adding some distilled water, you're gonna have a bad time. FL-22 is Glycol based, but it's been premixed so no need for that here. The rule of thumb is to mix green coolant though. 80% coolant, 20% distilled water and a shot of Water Wetter is about perfect.
You can use Prestone instead of Mazda's stuff and it'll work fine, but it won't last as long. Prestone will go 60K, and Mazda claims 120K for FL-22.
The orange stuff is called Dexcool and is made by GM. It's supposed to last longer, but there have been numerous issues with it. NEVER mix the two colors or the coolant will get thick like syrup which is no bueno.
...and the endless retarded threads aren't all that great either, chief.
