Just a little deconstruction to see the best way to come to the middle console to put there a LED [emoji848]or in the bottle holder-mmh right now new Idea. LOL
next time I try from above trough the aircon steering-that will work!!
Cheers 101
If I would have that engine, then I would certainly be changing my seats, to some sport ones. Even like this, I'm having issues sitting in the middle, after a hard turn.
Chris, that is with turbo?
I got her a cheap cover to keep the bird and squirrel poop, tree sap and leaves off her. I have not found an OEM cover for the 2017, not even sure Mazda makes one yet.
No turbo, just ecu tune and suspension mods
Yep. 2013 Volvo C70. The last year of the hard top Convertible. Couple months after we leased it they announced they were stopping production so we bought it out. Turbo.
Sent from my XT1585 using Tapatalk
Rotated tires for the first time since purchasing the vehicle and putting new tires on it last August. That was actually the first time I had the wheels off the car. Found the right rear shock blown @ 65K miles.
More reason to get rid of stock suspension (drive)
First oil change, installed Fumoto valve and got a whole bunch of oil filters (45,000 mi worth) from quirk parts. Castrol Syntec 0W-20. Only real complication was the factory installed filter was REALLY tight. Tried one hand, two, some vise grips, and ended up just having to hammer a screw driver through to get enough leverage. After that, everything went smooth. Looking forward to having an easier, cleaner time next time around.
Saw a new Honda CR-V the other day that was - according to the emblem, a "Touring" model. Thought it looked cool. So, I sourced one thru Amazon and installed it today just beneath the CX-5. Our CX-5 Touring is now a custom. ;)
As in the Touring emblem? (scratch)
Did an interim oil change at 15,000kms. Penrite 5W-30 DL-1 synthetic for the 2.2 diesel as per Mazda Australia specs.
The recommended service interval here is every 10,000kms, which I get the dealer to do, and i like to be extra conservative and do an oil change between services. No filter change, just drop and change the oil. I figure that th ~ $40 for the oil is a good investment.
I also do the usual checks of battery electrolite, radiator coolant, brake fluid, washer fluid tyre pressures etc at the same time. All good.
