 - Denver, CO
Mouth is watering...
For those who think 25% low gear lubricant in our small capacity rear differential is fine, just saw these in CX-9 forum:
Gross i can taste the metal from here
Aren't birds supposed to live on the tree?I swear half the bird population in my city live on the tree I park my CX-5 under. Did some QD and Stoners cleaning job. Yikes.
Yeah, I agree. New CX-9 inherited CX-5's i-Activ AWD system and it may be under-designed a bit for heavier CX-9. "4WD System High Load" warning even showed up in the video below at 0:44 seconds mark during the failed diagonal test. We have 0.48 quarts gear lubricant at most for rear differential with clutch pack from factory, I believe it could be very easy to get overheated during heavy usage for heavier CX-9 with such a small amount of gear lub. The gear lub capacities of rear differential with clutch pack for other AWD system I've seen are all at least 1.25 quarts.I agree that 25% low on gear oil is not fine but there's no way of knowing if that's what's causing this issue.
	Four new tyres fitted today...not cheap!
But I'm very impressed so far - under the EU tyre ratings they're the quietest tyres available in this size - I can hear the turbo spooling up whilst driving now! [emoji16]
What make and size tyre did you get?
They don't look standard size in the picture.
Oil/filter change along with a tire rotation. Used my new QuickJack and was happy to find out it can raise this vehicle high enough to swap the wheels/tires around. I also investigated an intermittent clunking noise I have been hearing, the right rear sway bar end link upper nut was loose. I went ahead and shimmed the studs with some 0.012 stainless I picked up the other day, I used 1 1/2 wraps around each stud. This is needed because the holes in the Corksport rear sway bar are very oversized for any factory Mazda end links. I'll keep an eye on the nuts, if either loosens again I'll see what I can find for better locking nuts.
Put a drop of loctite on it; that should do it.
