JDM led abmient light
Thank you i see it ,, i want it work when the ignition on and off when ignition off ? How figure that? The led is already plugged so what is the value of that wire with fuse? Its already plugged do i need to edit the led wire? Cut or what?
Refer to the post with the pictures, you need to insert the two posts into the plug and route the wiring harness down through the a-pillar and test out on the backside of the connection to see which wire is fused and switchable to come on with the lights.
Now this plug in the red circle dosent have a power??
<a href='https://postimg.org/image/f0bbpw8qd/' target='_blank'><img src='https://s18.postimg.org/f0bbpw8qd/IMG_3417.jpg' border='0' alt='postimage'/></a>
If the connector doesn't have a power why its plugged into nothing? My thought that the plug connector take the power from the electric circuit thats in the dome light and sunroof switch is that right or wrong?
You have to attach the red and black wire into the existing plug in order to provide power to the light, there are more prongs in the unit then there are wires in the plug there for you have to put the wires into the plug. Follow the post with the pictures, trust me, it worked for me.
Joaks: Do the Japanese directions have any pictures on/in them?
None, as a matter of fact there's no instructions at all, what those papers are thanking you for buying it and giving you things to check after install.
Sent from my SM-G935F using Tapatalk
Thank you I appreciate and apologize for too muck asking, i will try it and tell you what happens, so no need to plug anything to fuse box?
Just plug red and black , and ground to the nearest pin "nail"?
If you look closely to the connector on the side of the car ( the one that stays on the wire loom of the car) you'll see that the should be 2 empty spaces on the connector ( spot 3 and 4 i belive) you should put the 2 spade connector in there ( remember to open the connector if not you' re at risk of damaging the wires) then the 2 wires that you just added one should go to ground and the other to a power source (can be always on with car or only on with marker lights). When i get mine im going to try to do a small video about the install.
I think 2 and 4 same the post with picture
I will try to figure that and i will post photo here after finished
What about the A-pillar and side airbag?
Forget this thing after pulling a pillar you need to cut clip and buy new one to get back read that in another fourm , its hard to play with this thing AIRBAG :s
which fuse should i connect to because alot of amber there 10 - 20 - 25 -15 - 30? the fuse with the wire is 2A
The kit comes with replacement air bag clip it's the black one in with the wiring harness, you don't attach it to a fuse you use the red splicer to hook it up to the correct wire would you need to check by touching the wire from the wiring harness into the back of the main plug to see which one activate with the light switch.
Thanks i will figure wires which one is on when car ignition on i dont want it with light switch
guys i try to test the led with 9v its work but i think when i move the console i make contact by mistake between + and - the fuse was burn
see the fuse here
is this 2 amber fuse is enough when i attach to car ?
now i will try to find same fuse bad luck :(
JDM led ambient light
see the fuse here
Can you identify which fuse was burned? Check the fuse list in your owner's manual and figure it out. And make sure to use the same amperage of fuse to replace. You can also disconnect negative post from your battery for any future possible fuse damage.
All factory ceiling ambient lights are powered via the light switch. I was curious why you want it on even during the bright day time which serves no purpose? (uhm)
lol :D ,, first i didnt use it on car yet ,, i just plug it indoor with 9v battery .. its ok no problem i will buy new fuse .. second why i want all day on >> all cars now have same thing lexus kia Hyundai Cadillac all of them like what i want when ignition on light on when its off light off .. also i see this in kia rio standard :D its kia rio guys lol
i have an idea to connect led with the sunroof + i will figure that soon because i dont want to make alot of wires and remove A pillar its too much work
and if the dealer see any wires not original may be if there any problem in future they will cancel warranty for this reason dealer always looking for anything to tell you that your fault ;)
