2018 CX-5 Sunroof drain loose or clogged
Looks like the 2018 CX-5 front passenger sunroof drain is either loose or clogged. Water has been getting in the headliner for a year or so. Has not really been problematic but I need to get it fixed before it becomes a more serious mold/odor/damage issue.
Pouring water in the front driver's side drain I can see it pouring out underneath the car. Pouring water in the passenger side it seems to drain slowly, pool and never come out the bottom. Seems like if the drain hose was detached from the sunroof, it would never pool, and just drain into the headliner. Seems like it should be clogged somewhere.
I bought a snake with a brush from Amazon, and it seems to be able to snake "all the way" to the end. Have not removed any trim pieces so not 100% sure it is getting to the end. I asked some local shops about it and they would not touch it. Finally took it to a dealership and they want $750+, which seems like a lot.
Saw a few new YouTube posts and am going to try a few more ways before dropping that kind of money. First I want to find the drain exit and try and see if that is clogged, or snake from the exit, or verify the snake is getting all the way though. If that does not work I am going to try and drop the headliner in the corner to see if somehow the drain is detached.
If anyone has any suggestions or comments or advice, all is appreciated.
How different is your Amazon snek w/brush from, say, just some plain ol' plastic weedwacker line? I've heard of the weedwacker line doing the cleaning trick on a few occasions.
Basically the same thing. It is a flexible but stiff cable with a small brush on the end. The length should be long enough to feed the whole way, and it feels like it does, but of course I cannot see where it is actually going.
Well the drain hose was not clogged. It was simply not attached. I removed the visor, the handle and the A pillar trim. Dropped the headliner a bit and found the rubber hose nowhere near the drain outlet. Followed a YT tutorial and was done within 45 minutes. Sure beats the $750 the shop was going to charge!
Do you happen to have that link to the specific guide you found on YT?
Haven't had any issues on my own CX-5, with the drain hoses, but I'm sure it'll be nice to know how simple "popping" the trim pieces are in order to get to everything.
Glad that it was fairly simple, in your case. That ~$750 is roughly 5hrs of shop time. Can't imagine it took that long.
Agree on shop time estimate. I am quite handy but the shop guys probably could have done itnin <15 min
Great video for front drain tube fix...not so much for back drain tube's. Does anyone out there know exactly where the rear drain tube's end at the back of a 2013 CX-5? Any assistance is appreciated in advance.
I'm really happy I found this forum.
I am sure they are in a similar area to the fronts, but you would have to drop the headliner further back. Maybe start at the front side of the rear doors and pull the gasket as described in the video for the front doors?
I found this post on Reddit which explains the process for the rear in one of the posts:
Thanks very much for this info. I'm going to try it out as soon as my hand heals.
Glad you found it. My 2013 CX-5 is leaking from the right rear hose into the back seat footwell.
You wouldn't happen to know where the rear drains end in the rear wheel wells? I really don't want to tear down the headliner at the C pillar.
The problem will be behind the headliner, not the wheel well. Water is running from the top down. I recommend following the instructions in the reddit post below for the rear drains.
"To unblock the sunroof drains (there are 4) first check the front ones as they are easier to access. You can see small square-ish holes at the front of the sunroof channel when it is opened. Push some plastic trimmer line down the hole a few feet. Do it on both sides. Check the drain by pouring some water into the sunroof channel and see it come out near the front tyres. Test if the rear is blocked by parking on a hill and pouring water in the channels on both sides of the sunroof. Water should come out behind the rear tyres. If these are blocked you need to remove the rear passenger grab handles (they unclip with a flathead screwdriver) then take off the door seal. You can then reach up between the headliner and the roof and feel for a rubber hose. (Careful of the airbag) you can pull it off the hose barb at the rear of the sunroof (make sure there is no water left in it otherwise it will pour into the roof) clear the hose by blowing into it or pushing the trimmer line down. Clear the barb with the trimmer line. Reconnect the hose and replace the trim etc. now water should drain at the rear."
Thanks for that advise. Gonna try that today.
$750??? I am glad I did the same thing you did and saved a chunk of change. Mine was disconnected as well but there was tension on the drain line I couldn’t trace. Ended up using an adjustable screw clamp to keep it secure. Probably could have used a zip tie but this seemed better in the end. Some helpful links from You Tube below for anyone else having this same problem.
Removing the A pillar (no need to remove the weather stripping, you can just reach under it to grasp the trim edge.
youtube.com/shorts/jOPnoiT5L2c?si=Wcr43Acd2Orgb7XI
Removing the grip handle
youtu.be/tvFeUWBOigI
Removing the visor clip if you need more room under the headliner
youtu.be/nYQ7Q5LPQTY
📦 Need Mazda Parts Fast?
Get Free 2-Day Shipping with a 30-Day Prime Trial
Try Prime Free →
