CX-9 Blower Fan Help
wcbzero
2008 Mazda CX-9
Hello I have a 2008 Mazda CX-9 and the blower fan is moving incredibly slow, after the AC Drain got clogged, and the unit filled with water.
I successfully unclogged the drain, and the fan spins, but it is not fast enough to defrost the windows. :(
The fan also sounds a bit like a record player scratching. I shot the video below from the filter replacement door, with the fan set to max speed to demonstrate. (After taking the video I noticed the debris in the fan, and have removed it and get the exact same results).
https://www.youtube.com/watch?v=RH4YGYHApfo
At this point I suspect that I either need to replace the motor, or the motor resistor, but am hoping for advice as to which one (or both) before ordering parts.
Thanks in advance!
Thanks in advance!
from what I can tell from video, it loks like the motor got water logged and rusted and needs to be replaced, some fellow CX-9er's have successfully replaced with this blower from Amazon instead of the pricey Mazda OEM one, just letting you know.....
https://www.amazon.com (commissions earned)
https://www.mazdas247.com/forum/showthread.php?123853848-How-to-change-a-fan-motor-for-2011-cx9
Thanks for the advice! I bought a motor locally and everything is back in working order!
