- 2016 CX-5
Can someone who has done the transfer case oil change please confirm that these are the drain and fill plugs ? thanks very much
Yes. Take the fill off first in case it's stuck for some reason you aren't messed up.
got it, thanks Chris, much appreciated ! I was planning to service it myself at 15,000 miles , is that good ? or should I do it sooner ?
According to owner's manual, you should only change the gear lubricant in front transfer case and rear differential at 30,000-mile interval if your AWD CX-5 is driving in the "severe condition". Or change them immediately after the components have submerged in water.got it, thanks Chris, much appreciated ! I was planning to service it myself at 15,000 miles , is that good ? or should I do it sooner ?
