sbronemann
- 2014 Meteor Grey Mazda 6 Touring
Got my Xenon Depot HID kit and Phillips LED fogs put in! What a difference!
A lot of good things happening in here.
Thoughts on this? Not sure if I should call the dealer to have it checked, cut it off or just stuff it behind the dash. Only thinking of calling the dealer as I am not sure if its part of the windshield seal. If its for sound deadening I will simply stuff it back behind the dash.
Sent from my Galaxy S7 Edge using Tapatalk
^ haha I had it in the exact and I mean exact same spot. When I installed my tweeters I just cut it but for some odd reason it seems to have slightly returned....creepy
It's not a seal, it's a self-adhesive foam strip that is applied to the lower rear edge of the dash to stop potential rattles or squeaks against the windscreen. It runs the entire width of the dash so the small length that has torn on you will not cause any issues. I would push it back down rather than cut it though, if something small or thin rolls off the dash towards the windscreen, it could stop it falling behind and allow you to hook it back up.
What type of paint are you using?Getting rid of that corny chrome line and re-coating my emblem while I'm at it.
Priming.
Sent from my Verizon Note 4 using TapTalk
Priming.
Priming.
