Hot and dry weather is upon us again and I live on gravel, which results in a lot of dust.
This car never used to leak, but it started sometime late last summer.
If I put the A/C on fresh air with all the windows closed it's not as bad (positive pressure in the cabin), but if I drive with the sunroof open or a window cracked with the A/C on recirculate it gets really bad, you can see the dust floating around. After a couple weeks, the back seat will be covered in dust.
Anyone dealt with this before? What should I check out aside from door seals?
